Swift Sixteen
- TheChestnutLine
Swift Sixteen
Hi guys,
For christmas I've asked for a D class wagon by swift sixteen. I've already looked at the instructions and it says I'll need a rivet embossing press to punch the imitations in the brass. The tool they suggest to use is £62 which is quite a lot. I was wondering if anyone else had another method or tool they have used on their brass work?
Kind regards,
James
Kind regards,
James
James
- sstjc
Annie
- andymctractor
Just be careful. I used one on an Andel models kit and it split the casting. The resin SwiftSixteen uses is probably different but I think the problem was too much spring strength even when wound out, if that is the correct terminology.sstjc:114738 wrote:Just wondering if you can use an automatic centrepunch with the spring wound back. £62 quid seems to make the kit very expensive to me.
Barry
Andy McMahon
Andy McMahon
- Keith S
Can you use a dulled drill bit or something in a (non running) pillar drill? I was thinking of doing this.
I have a Swift Sixteen roof hatch kit for a steam locomotive and I've been afraid to start putting it together because of these rivets. I don't want to stuff it up by ruining the rivets. Also don't feel like buying one of those rivet embossing press thingies.
I have a basic drop-weight system which is a steel rod with a pointed end and a weight which circles the rod. At the top it is threaded with locking nuts to maintain consistent drop height. Try it out first on a sample piece of the material to be used and set the height accordingly. Simple but effective (and cheap!!!)
- TheChestnutLine
I think if I didn't get the rivet punch, Keith, I'd probably end up in a similar situation to you and put off starting the kit, which is a situation I don't want to be in! £60 is just far too much for me. I intend on buying a few more kits in the future but I don't kit build very frequently so it just seems a lot of money to invest into a machine that will be hardly used. I might drop Rob an email unless he sees this post?
James
- GTB
If you have a drill press you are 9/10ths of the way there. All you need is a suitable punch and die for the size of rivet you want.Keith S:114750 wrote:Can you use a dulled drill bit or something in a (non running) pillar drill? I was thinking of doing this.
I posted this back of the envelope sketch in another thread a while ago. It's based on one a friend uses in his drill press and it works well. I got carried away and built a scaled up version of the NWSL Riveter to use in my mill/drill, but it doesn't work any better than the one in the sketch.........
If you know someone with a lathe, the punch and die are a simple turning job in mild steel. It would be possible to turn and drill the parts in the drill press with a file if you are careful.
If all else fails, NWSL in the US have their Riveter back in production if their website is to be believed and they sell alternative punch and die sets for $6.00 US. The 0.050" inch set is about the right size for SM32/45 scale.
The MetalSmith rivet press shown in the Swift sixteen instructions also has spare punch sets available which could be used in a bench drill, but they are a bit more pricey than the NWSL parts.
- Keith S
Sigh. I would pay Rob a little extra to do this work for me and send the kits out with rivets already pressed.
Thanks Graham, I will start looking around for some bits of steel to make the parts you described. I guess when I eventually get around to scratch-building a locomotive (an ambition of mine) I will have the tools ready so it can have lots of rivet detail.
- River Lin
Hi Keith.
That's the big thing with scratch building. I am a scratch builder of NWNG coaches and having all my little homemade tools and jigs stored away and available to use again saves time and gives satisfaction. So my advice is to make that jig, use it and then put it on a shelf for next time. It will give you a good feeling next time you need one to be able to just pick it up and use it..
David
David
David T.
- TonyW
Just a suggestion, but you could always just drill the rivet holes and solder in real rivets...
- Lonsdaler
Gives precise control for consistent results:
http://www.eileensemporium.com/index.ph ... t&Itemid=9
Pictures are so much better than words... thanks to BaBBLR we can now see the item I was trying to describe earlier in the thread.BaBBLR:114809 wrote:Gives precise control for consistent results:
- AFGadd
- GTB
- GTB
That's the way it works, you accumulate tools and jigs on the drip feed as you need them. The other thing to start accumulating is a good scrap box. Also worth getting a copy of Brian Wilson's book while it is still available.Keith S:114791 wrote: I guess when I eventually get around to scratch-building a locomotive (an ambition of mine) I will have the tools ready so it can have lots of rivet detail.
