Concrete casting
godsteam
Concrete casting
I would like to cast a station platform and a tunnel mouth. How do I get the stone blocks effect in the mold?
And any other tips would be appreciated.
Godfrey
Godfrey
Re: Concrete casting
You can scribe the courses when the cement is in its 'green' state.godsteam:109907 wrote:I would like to cast a station platform and a tunnel mouth. How do I get the stone blocks effect in the mold?
Godfrey
I've also used lines of hot glue on the sides of my mould to indent mortar courses - see - http://riksrailway.blogspot.co.uk/2010/ ... idges.html
For platform edging, I've used another couple of techniques.
1. Creating a mould and attaching stone 'slips' to the inside of the mould with grease.
http://riksrailway.blogspot.co.uk/2007/ ... forms.html
2. Casting platform edging from JigStones moulds and then using them to define the platform edge before infilling with concrete
http://riksrailway.blogspot.co.uk/2009/ ... stock.html
I've also scribed on the edges when the concrete is 'green'.
Of these three approaches, I'd say the JigStones mould is the most effective and the scribing is the least as I used gravel in the concrete mix and the stones in the mix prevented clean scribing. Might be OK if no stones are mixed with the cement but it might then make the concrete more brittle.
BTW - I do love concreting - one of the joys of garden railway modelling!
godsteam
Steve at Back2Bay6 used to be the supplier in the UK - but alas no more. I used to have a full set of moulds for stone and brickwork but I sold them on eBay. Maybe I should have held on to them - sounds like they would have been an heirloom.godsteam:109928 wrote:Thanks for that advice Rik
I have heard of Jigstones but the molds seem to be just available from the German supplier now at £43!!
Godfrey
- andymctractor
Here is a link to a previous topic on concrete roads and platforms.
http://gardenrails.myfreeforum.org/abou ... highlight=
Here is a photo of Bramley Bank showing a platform built using jigstones edging. This is an effective but labour intensive method. I have one mould but needed just under 50 castings for this station.
Good luck.
Good luck.
Andy McMahon
Andy McMahon
