Painting Wood
JMORG
Painting Wood
Post by JMORG » Mon Oct 21, 2013 6:14 pm
Hi all,
Just recieved some Swift Sixteen crates.
After surfing the internet (and through A LOT of Warhammer forums!) I am struggling to find a way to paint it in a convincing, weathered wood effect.
Suggestions?
LnBmad
Post by LnBmad » Mon Oct 21, 2013 6:21 pm
What sort of wood are you wanting it to look like? By weathered how has it weathered?
JMORG
Post by JMORG » Mon Oct 21, 2013 6:25 pm
Well they would be soft-wood (such as Pine), and the weathering would simply be as if they've been left outside in the rain for awhile (less is more).
LnBmad
Post by LnBmad » Mon Oct 21, 2013 6:28 pm
Start with your base colour. You then need to dry brush in the direction of the grain. I would then use sponging and washes to add the weathering - I'm ex Gw staff so I know nothing though ;)
Post by MDLR » Mon Oct 21, 2013 8:19 pm
If you're working with ply, go out and buy yourself a bottle of Indian Ink. put a small brush full in a LOT of water, and experiment until you get the right colour - less is once more more........................ You can put further coats on to increase the effect.
andymctractor
Post by andymctractor » Mon Oct 21, 2013 11:04 pm
As the crates are made of resin but you want them to look like wood I would suggest Tamiya Acrylic wooden deck colour. It dries to a matt finish looks like wood and takes weathering powders very well, once dry. I've used it on a few kits where wood is represented in resin castings. Just be aware though that it dries quickly and might catch you out if you overbrush it.
Andy McMahon
