I was wondering of there are any dealers who convert track powered locos to battery power?
Id convert my new LGB tram myself but am crap with electrics.
battery conversion
pauly
battery conversion
A steam propelled life-style.
made-in-england
I'd rcommend NOT wiring to the track pick-ups unless your track is configured correctly (ie no balloon loops like you have on your tramway extension Pauly) - otherwise you've got a short circuit across your battery.
My LGB chassis have the pick-up skates and the plungers that pick up current from the back of the wheels removed as the first job.
As you're doing this you'll see where the wires connect back to the motor connections. This is where you need to connect your new power source.
Either a simple battery/DPDT switch or battery/DPDT switch & speed controller will work, I've done both now since I worked out which end of the soldering iron to use
