new jigstone building
mymodeltrain
This is my new jigstone building, made from polyurethane resins.
Re: new jigstone building
Very nice! You've done a lovely job of painting the stonework. I like the posh garden wall too!
- BorisSpencer
Diamond leaded lights, very posh!
Now that's something that would 3D print nicely. Must look for a suitable local prototype.
That must have taken ages to cast all the individual components. Presumably you had the mix the resin in very small batches. I suppose the upside is that the resin will set more quickly than concrete.
Looks great. I like the mullioned window frames.
- thornmini
Really nice and well made building -- should last a long time. Like Rik, I do find your windows intriguing. They appear to be homemade, and if they are, I would enjoy knowing your process -- especially if I could follow and make my own. Thanks!
Waldeker EisenBahn
mymodeltrain
Rik,ge_rik wrote: Fri Feb 19, 2021 9:59 am That must have taken ages to cast all the individual components. Presumably you had the mix the resin in very small batches. I suppose the upside is that the resin will set more quickly than concrete.
Yes, resin heals quicker than concrete. Usually, I can do the casting in the Summer only, and it would take one day for the concrete to cure. While resin heals in 10 min at 50F; so I spent only one hour a night for three nights to get all the bricks I need for the building.
At different temperatures, the color of the product is different. I guess when it is cold the resins didn't diffuse fast enough and they became brown, but when I used a heating lamp, the products are white. nevertheless, I don't mind, since they are equally strong, and I can paint later. To speed up the construction, I used JB Weld epoxy glue. The healing time is 10 min versus 24h if using liquid nail. This is a very large building. It would be difficult to make it with concrete for the weight. I used an aluminum beam to hold the bricks together, or else the building would fall apart if I lift it up. The other advantage of resin is that I also screwed the beam into the bricks. To trim and cut the resin-based bricks, I used the sharp blade and wood chisel, respectively. But when I need a more precise cut, a tiny metal hacksaw is great.
The window frames were made of thick wood so they can fit in the thick bricks nicely. While, the mullions are from metal gutter guards. I used super glue to glue the mullions onto the wood frame. Please be careful when using superglue, eye protection goggles are required during this process.
While the doors were made of 3 mm-thick acrylic sheets, and I used the ceramic tile table saw (the blade has no teeth, so it is pretty safe to use) to cut them into small panels. This is the first time I can cut plexiglass into small pieces using the same device to make the door glasses.
The roof was from my house roof; It may not look very nice, but it will survive all weather conditions. An aluminum bar was placed below to ensure the roof will not bend over time.
Finally, dry-painting method must be pointed to Rik's website for further instructions.
Thanks for the detail. I've used JigStones three times - once for platform edging, once to construct a cattle dock and once to produce cobble stones. I cast my blocks with rapid set cement and fine sand. On each occasion, I picked a warm summer's day and got a sort of production line going. The cement took around 15 mins to set sufficiently for the block's to be removed from the moulds, but they were quite fragile until they fully hardened off - which took at least another 24 hours.
Resin sounds like a far better medium.
Thanks for showing the inside as well. It gives a much clearer perspective on how the building was constructed (even though it's not as pretty as the outside).
mymodeltrain
mymodeltrain wrote: Fri Feb 19, 2021 2:58 pmRik,ge_rik wrote: Fri Feb 19, 2021 9:59 am That must have taken ages to cast all the individual components. Presumably you had the mix the resin in very small batches. I suppose the upside is that the resin will set more quickly than concrete.
Finally, I completed the design with some weatherings and installation of the lights for the building, and I will bring it out to the garden today
Looks great! The mossy green roof is an interesting sight; we have nothing like it here in hot, dry Oz.
mymodeltrain
I brought the building out to the garden during the weekend and wiring to light it up.mymodeltrain wrote: Sat Mar 06, 2021 6:48 pmmymodeltrain wrote: Fri Feb 19, 2021 2:58 pmRik,ge_rik wrote: Fri Feb 19, 2021 9:59 am That must have taken ages to cast all the individual components. Presumably you had the mix the resin in very small batches. I suppose the upside is that the resin will set more quickly than concrete.
