Removing a spring from an Acoms Technisport transmitter
This section is useful for posting interesting copies of instruction manuals and similar pieces to help other members of the hobby
MTA
Post by MTA »
Just a few tips on this:
1) The spring is held onto the reversing lever in the handset by a notch AND glue. This is also the same for the other end of the spring.
2) When putting the handset back together, the leads to the battery terminals on one half can get trapped between the two halves. Poke them in with a piece of strip and the transmitter will squeeze them into an allocated gap.
Also the aerial fits into two ledges. So if it is loose upon reassembly they aren't located properly.
ACLR
Post by ACLR »
good tips there Si
Post by laalratty »
Thanks for posting this, could be useful, although I am still going to stand by my lego brick version for the time being ;)
Palmerston
Post by Palmerston »
I took this pic when removing the spring of the steeringwheel on the TX supplied with Criccieth Castle back in January.
Acoms Technisport 2.4Ghz
Desolder the 3 spots within the red-circle, center of pic ;)  as the main circuitboard needs to be removed to gain acces to the spring. The lever and spring of the trottle are in the bottom of the pic. Exactly the same are fitted to the steeringwheel. Mark the center of the wheel on the outside of the casing so the adjustable resistor is put back in the same setting as it was removed.
MTA
Post by MTA »
That's odd, the wheel on my tx doesn't have a spring! Only the reverser did :shock:
Palmerston
On CC the wheel controls speed and direction so Roundhouse probably thinks the wheel needs centering to keep the loco on hold.
