Mamod piston fastening tips
Joe
Hi all, one thing ive found very difficult with my mamod is trying to put the piston back on the pivot bolt (with spring) as the spring pushes back and its very hard to get the tiny thread of the bolt to enter the hole int he cylinder. Any tips you have would be appreciated.
cheers
Joe
cheers
Joe
DLRdan
Joe
- Sir Clothem Cap
remove the piston assembly from the loco, sort out the piston then reassemble. it is very fiddly to do it on the loco.
Some locos have 2 nuts and bolts and 2 screws holding on the piston assembly others have a mix of rivets and screws. If yours has rivets these can be drilled out and replaced with nuts and bolts
Joe
ok, well after fixing the steam leak etc it ran well but when i tightened the nuts holding the cylinders to the frames the cylinders fell off (and nuts and springs) it was all working so well
so now im left with this:
at least i know when its all tightened and fixed on correctly she will steam very well its just now a case of putting the cylinders back on and i dont really want to take the frames apart as im not that knowledgeable on these matters.
- dougrail
Joe
Yeah thanks Doug , I realised I could do that after suddenly having a rare eurica moment
, just waiting for a nut spinner set to come in the post and then I should have it sorted by this weekend for a steam up . I've got my short circuited diesel to Contend with next
I live near halesowen at the mo, how about you ?
Joe
- Chris Cairns
Both the Dream Steam ( http://www.dreamsteam.co.uk/mss-mamod-u ... nders.html ) and Roy Wood Models ( http://roywoodmodels.co.uk/mamods ) upgrade cylinders are the same price - £50
The Dream Steam ones have an advantage that they are fitted with a 2nd end cap, thus making it easy to replace the 'O' ring on the piston if necessary. I have no experience of the Dream Steam upgrade cylinders and I do not recall anyone having problems with them (that was their previous upgrade steel wheels, and I know someone had a problem with the end caps popping off on PPS Steam upgrade cylinders).
I have a set of RWM upgrade cylinders fitted to my PPS/RWM De Winton project and they work very well indeed. They have lots of power available and there are no steam leaks between the cylinder & the back plates.
Doug (dougrail) is probably the best Forum member to ask regarding the current Dream Steam upgrade cylinders. My experience is limited to Mike Chaney, MGM Engineering, IP Engineering, PPS Steam & RWM upgraded 'O' ring pistons & cylinders.
(edit - added IP Engineering to the list)
