lynton and Barnstaple manning wardle
LnBmad
Guys, I'm looking to make a live steam manning wardle in 16mm. I want to have fully working joy valve gear but am unsure as to how to work out the throw in the steam chest... Has anyone else made on of these locos? I know accucraft sell them but I would prefer to make one am just struggling with the valve gear.
Colinjamesporter
I can recommend this book for what your lokking for. http://www.camdenmin.co.uk/model-locomo ... -3136.html it covers all types of valve gear.
Best wishes
Colin
Best wishes
Colin
LnBmad
I'll take a look at that thanksColinjamesporter:84256 wrote:I can recommend this book for what your lokking for. http://www.camdenmin.co.uk/model-locomo ... -3136.html it covers all types of valve gear.
Best wishes
Colin
LnBmad
LnBmad
Was kindly offered a second hand set of roundhouse cylinders so will fit them on this loco. Other locos in planning stage will have to have scratch built cylinders.
This one will be slip eccentric using homemade eccentrics and rods. The design layout does allow for me to upgrade to full joy valve gear at some point if I can get my head around the correct dimensions.
INJIN
Well done for taking this bold step Mr L&B. You will not regret building a loco from scratch. When I built my first loco a VOR 2-6-2 a couple of years back I well remember being at this stage. All of it was new to me & I wondered if I'd ever actually finish it. However a year later it was complete, painted & ran a treat.
I'll look forward to updates & hope it all goes as well for you as it did for me.....
Cheers
Keith
Cheers
Keith
LnBmad
- Dannypenguin
This'll be an interesting one to follow
Dan
LnBmad
INJIN
Just a thought here.
When Roundhouse built there L&B loco's they avoided the frame cut outs by splaying them out at the front & rear to allow the trucks to swing. Visually this is much better & you can't notice it unless you look very hard.
However if you want the loco to go round very sharp curves IE Mamod there is no other way than to make cut outs as you have done
Below is a Roundhouse L&B
This is Paul Millingtons scratch built EXE, it to has splayed out frames. You can't even tell from this picture.
Cheers
Keith
Cheers
Keith
- GTB
That's a good idea. I take it the brake cylinders disguise the dog leg in the frames at the rear, the same way the cylinders do at the front?INJIN:96424 wrote:When Roundhouse built there L&B loco's they avoided the frame cut outs by splaying them out at the front & rear to allow the trucks to swing.
What's the valve gear on the Millington engine? It looks like 'simplified' Walschaerts modified to resemble Joy gear......
LnBmad
INJIN
LnBmad
LnBmad
Wow! It seems I haven't updated this project in a while...
Bearings are now done. Slip eccentric parts on order from dave (hglw) as getting the drawings and time in the workshop to just make them is rare. Axles now in 1/4" silver steel. Pony and trailing trucks made and fitted. Motion bearings fitted. Fake expansion links made to carry motion to the valves.
Happy to say I'm nearly at an air testing point
LnBmad
