Emptying gascans...
St.Michael
Emptying gascans...
Post by St.Michael » Thu Aug 02, 2012 9:22 pm
Hello everybody.
Here is a simple question that maybe someone out there has an answer to: Is it possible to fill with a gascan untill it gets completely empty :?: I have a lot of "empty" cans, but I think I still hear liquid gas inside when I shake them. I stop using a can when I can´t manage to notice any more gas going in the gastank.. The preassure is of course low in a can that is almost empty.Could that be the reason? But then, gas is heavier than air, so logically the whole content should just drain into the gastank when filling the loco. Shall I throw my old cans away, or is it more gass in them?
TonyW
Post by TonyW » Thu Aug 02, 2012 11:56 pm
I finish them off to completely empty by using them with my blow lamp.
Re: Emptying gascans...
Post by GTB » Fri Aug 03, 2012 10:08 am
St.Michael:73455 wrote:Is it possible to fill with a gascan untill it gets completely empty :?
It depends on the type of can.
The expensive ones for filling gas lighters don't retain much, if any liquid. The cheap ones are designed for camping stoves and have a dip tube with a right angle on the end, so they don't feed liquid into the stove burner. The dip tube prevents all the liquid being fed out when held upside down to fill a loco tank.
I use the cheap camping butane and like Tony W, I use up the remaining gas in a blowtorch that is designed to fit these cans. I've not measured it, but the torch runs for quite a while on an 'empty' can.
St.Michael
Post by St.Michael » Sat Aug 04, 2012 7:09 am
Thank you for interesting answers :!:
That really explains things for me. Maybe I should buy a blowtorch, what are the using areas for such a tool?
Michael :)
dws
Post by dws » Sat Aug 04, 2012 7:19 pm
St.Michael:73500 wrote:Thank you for interesting answers :!:
Michael :)
I use my blowtorch to burn off the weeds on my garden path.
Post by GTB » Sun Aug 05, 2012 6:24 am
St.Michael:73500 wrote:Maybe I should buy a blowtorch, what are the using areas for such a tool?
I use mine in the workshop for soft soldering large parts and for medium size silver brazing work. It can handle brazing a gas tank, but wouldn't be up to doing a boiler.
If you don't have a workshop, visit a camping store and get a small stove that uses these cans. You can use it on the railway to brew the drivers tea on running days..... ;)
ps. Here in Oz you can get weedburners that also use these cans, but I've no idea if they are sold in Europe.....
