Flat Wagon
Alan P
Flat Wagon
Post by Alan P » Sat Sep 12, 2015 9:35 am
It would appear that i'm becomming a Phil Sharples Kit Junkie! Oh well i suppose there are worse things to be addicted to :)
This is his basic Flat Wagon Kit. Fortunately the chassis parts are similar in dimensions to his Coal Wagon Kit and fitted into the jig i built for that wagon nicely.
The full build will be covered on my website here http://www.alspcs.com/PSBFlat.html
Post by MDLR » Sat Sep 12, 2015 3:26 pm
That's interesting - I never felt the need to use a jig for the coal tubs as putting the verticals in position made a ready-made location for the top and bottom layers.
Alan P
Post by Alan P » Sat Sep 12, 2015 4:00 pm
I don't suppose it matters which way you do it Brian. I built the chassis first and put the verticals in afterwards.
With my Coal Wagons i found that aligning the rivet detail on the verticals with the centre of the planks meant
that the verticals didn't reach the bottom layer. I also had 8 to do and just thought the jig would make life easier :)
Alan P
Post by Alan P » Fri Sep 18, 2015 4:20 pm
Ok, here's the completed flat wagon. Just need to make a suitable load for it now.
Just in case anyone is wondering, the side lugs and tie down rings are not currently part of the kit.
Post by Soar Valley Light » Fri Sep 18, 2015 7:10 pm
Super work Alan, that's a lovely model. :salute:
Alan P
Post by Alan P » Fri Sep 18, 2015 10:29 pm
Thanks but as i've said before most of the credit should go to Phil, his little kits are excellent. :)
