Cheap Wagon Kits
Cheap Wagon Kits
Post by Big Jim » Sat Apr 25, 2015 11:31 pm
Some of you may have already seen these on ebay. T
I bought a few of the coal wagon kits http://www.ebay.co.uk/itm/sm32-16mm-sca ... 7675.l2557
I felt the need for a spot of light relief after spending hours on more complex kits
For your eight quid you get some nicely cut MDF and acrylic parts and what I think are Binnie wheels.
ImageDSC_0071 by bigjimiflash, on Flickr[/img]
The detail is quite good on the model and what did impress me was the 'planks' are cut right through.
I timed myself building one and managed it in less than 10 minutes.
For less than the cost of a round of drinks I am very impressed. The fit of the parts was spot on (better than some much more expensive MDF kits).
The seller seems to have a varied range of wagons available from time to time. The oil drum wagon has already been mentioned on the forum. There are also flat wagons and small coal wagons.
ImageDSC_0072 by bigjimiflash, on Flickr[/img]
ImageDSC_0073 by bigjimiflash, on Flickr[/img]
2horse sam
cheap wagon kits
Post by 2horse sam » Thu Jun 18, 2015 6:10 pm
Tipper wagons now too
listerboy
Post by listerboy » Fri Jun 19, 2015 1:34 am
Are they available in 45mm gauge?
Post by bazzer42 » Sat Jun 20, 2015 9:07 am
He certainly does a flat wagon in 45mm. Added a bit of weight and it runs a treat. He hasn't got much up for sale at the moment but they come in frequent large batches so keep your eyes peeled.
Post by ge_rik » Sun Jun 21, 2015 10:28 pm
listerboy:111604 wrote:Are they available in 45mm gauge?
Hi
I enquired about 45mm kits from VWMonkey (Phil) and got this reply
Hi Rik, thank you for letting me know your kit arrived and very sorry for the late reply. I do a flat wagon and a slate wagon to run on 45mm track, but to be fair they are more 16mm scale. I have been looking into G scale (if that's the scale your friend requires) but I've not got any kits as yet, but please keep an eye out.
Phil.
listerboy
Post by listerboy » Mon Jun 22, 2015 7:31 am
I'm 45 mm, which is close enough to 3 ft gauge for me!
Post by 90733 » Mon Jun 22, 2015 8:52 am
Yep, he does the slate wagons and flat wagons in 45mm gauge. I think he might be looking into one or two other wagons to release in 45mm gauge also (possibly the barrel wagon). The 45mm version generally requires a bit of a redesign as they are wider than the original 32mm gauge versions, the flat wagons and slate wagons been produced after some requests.
Jack (VWmonekys son ;) )
Thanks
Jack
