Wheel diameter
pskipper
Wheel diameter
Post by pskipper » Sat Feb 21, 2015 10:30 am
When wheel diameter is quoted for a loco is it the full diameter including the flange or the diameter of the bit that touches the rail?
Thanks,
Re: Wheel diameter
Post by GTB » Sat Feb 21, 2015 12:55 pm
pskipper:108400 wrote:When wheel diameter is quoted for a loco is it the full diameter including the flange or the diameter of the bit that touches the rail?
The quoted dia. of a protype wheel is as measured over the tread, not over the flange. Put simply, yes, it's the dia. of the bit that touches the rail.
Because most (but not all) prototype wheels have coned treads, the convention is that the measurement point is at the root radius, where the flange meets the tread and model wheels follow the same convention.
The wheel profile diagram on the 16mm Association standards shows how it works for model railway wheels if the above is as clear as mud........
http://www.16mm.org.uk/newsite/files/de ... tml#wheels
pskipper
Post by pskipper » Sat Feb 21, 2015 1:06 pm
Nope, that was perfectly clear, thank you. Some ebay bidding may be going on in the next day or two :)
pskipper
Post by pskipper » Sun Feb 22, 2015 8:20 pm
Thank you again, the loco in my signature now has wheels :) Nothing else yet but wheels are a good start :)
