dclavey
Post
by dclavey » Thu Feb 05, 2015 11:23 pm
I have just bought a case of 80 year old Lionel O Gauge O31 tubular Track on ebay for 99p. I am using it as a test track for my SM32 HGLW diesel Loco and carriages.
Example of SM32 using Lional O Guage (with middle rail removed):
https://www.youtube.com/watch?v=d0Ib2pbVSv4
The track is very grimy and a bit smelly, I wondered what I should use to clean it ?
dclavey on Thu Feb 05, 2015 11:40 pm, edited 1 time in total.
CLAVEY Models is owned by David Clavey, creating 3D drawings of Garden Rail parts and 3D Printing them in the UK. I belong to the Association of 16mm Narrow Gauge Modellers SM32/45. But also run g gauge o gauge and 7/8ths models in my Garden.
David
Post
by MDLR » Thu Feb 05, 2015 11:31 pm
I stick Mamod track in the dishwasher (when SWMBO is not around..............)
dclavey
Post
by dclavey » Thu Feb 05, 2015 11:44 pm
No dishwasher unfortunately.
Wife says, how about WD40 and cotton wool ?
David
Post
by MDLR » Fri Feb 06, 2015 12:49 am
Hot water and washing-up liquid, followed by WD40 and a green scouring pad - shouldn't take the plating off .
big-ted
Post
by big-ted » Fri Feb 06, 2015 7:07 am
MDLR:107996 wrote:I stick Mamod track in the dishwasher (when SWMBO is not around..............)
Do you not find this takes the black paint off?
Post
by MDLR » Fri Feb 06, 2015 9:59 am
It didn't when I did it last year and I wouldn't want todo it TOO often, but it hadn't been cleaned for about 15 years................
Post
by Big Jim » Fri Feb 06, 2015 10:43 am
Avoid fairy liquid as it contains salt and will exacerbate rust. Have used autoglym car shampoo on some old b/lowke tinplate with a tooth brush. Autoglym has a rust retarder in it.
Post
by tom_tom_go » Fri Feb 06, 2015 11:49 am
If you are not running power through the track do you need to clean it as it looks weathered
dclavey
Post
by dclavey » Fri Feb 06, 2015 12:20 pm
No, not running power through track, so like rugged look, but would like it less smelly, and less dirty too touch.
Mind you this is probably 80 year old track, so probably has 80 years of grime!
I am mainly using it as an indoor test track.
David
Users browsing this forum: No registered users and 43 guests
