Hi all
i had forgoten all about this forum. sorry if you think my line has become spam. not posted here for some time but have other places.
now days i mostly post to my lines page on facebook. but i have uploded all of 2014 photos to flicker. my line has gone very FR/WHR ish
https://www.flickr.com/photos/69363786@ ... 943744558/
2014 Sesson on The line with No Name
Looking good, thanks for the photos!
As for "going FR/WHR-ish", I understand entirely! There are worse things that can happen to a chap...
What are the origins of your model of "Mary Ann"? I want one! I've considered Swift Sixteen's kit, but I think the motor might pop up into the cab, which is so lovely and empty on yours. Looks powerful too?
thecsmann
Its one of the ones made by andel , but I took the doors off and some of the armer , and a repaint, to make it look like it did when it first arrived on the fr. Has battery's and rc hidden under the details . is powerful but has a small motor which if run for long over heats! Do not think an del made meny .
Ah, thank you... I've got an Andel Moelwyn but I'm a little wary of over-use too. I stripped the original nylon gears very early on and although Andy replaced them with metal ones the motor and gearbox are hidden away inside and I think I'd have to pull the thing apart to access them in the event of a repeat occurrance...
The green paint you've used is just the sort of thing I'm looking for for Moelwyn - you don't recall what sort you used do you?
Thanks,
Thanks,
thecsmann
