Fixing track
Kubes
Fixing track
Post by Kubes » Wed Aug 20, 2014 10:06 am
Hi what's the best way to fix track to a wooden base - screws or nails? I used screws and plugs on the concrete section but the raised section is on timber planks. Thanks
Post by Peter Butler » Wed Aug 20, 2014 10:15 am
I doubt there is a 'best way' just the way you feel happiest with! I use screws on my timber base but I always use screws, not nails, for any fixing. Nails are less obtrusive and can be applied quicker (I guess), although I would still drill holes in the sleepers to prevent cracking and splitting, and use panel pins with small heads.
steamie1
Post by steamie1 » Wed Aug 20, 2014 10:27 am
Make sure you pre drill the sleeper and use brass or stainless screws. Don't screw down too tight.
Kubes
Post by Kubes » Wed Aug 20, 2014 12:25 pm
Thanks guys - screws it is then!
Post by Andrew » Wed Aug 20, 2014 1:34 pm
I found some little black dome-headed screws (B&Q I think) which I used for recent track-laying (Peco onto wooden decking boards), very unobtrusive...
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Wed Aug 20, 2014 3:00 pm
Just to throw more into the mix I'd recommend steel nails over brass, they will rust into the wood and won't work loose as a brass screw might, I leave mine with enough sticking out so that with a pair of pliers and a little elbow grease they can be removed if you change your mind about the track layout.
Graff B.
Post by Graff B. » Wed Aug 20, 2014 7:46 pm
I have track fixed down to a wood base with steel panel pins. Most of it has been down about 15 years with no major problems.
Post by bazzer42 » Wed Aug 20, 2014 10:17 pm
Just to add another dimension, I use stainless steel security screws from good old screwfix.
Kubes
Post by Kubes » Wed Aug 20, 2014 10:48 pm
Just goes to show there's never one correct way to do something. I'll have to have a look at the Screwfix catalogue and decide!
