Glue for polystyrene kit??
- Mrs F Controller
Purchased a Nissen hut from Modeltown and put it all together with P38 body filler as it sticks can sand paint etc. But, the rounded corrugated roof is some form of polystyrene and so far I've tried body filler again, super glue and silicone all that happens is it peels straight off! Can't use araldite as it goes too runny and won't be able to put it on easily so that when it starts to flow it doesn't end up everywhere! Any ideas??
I was about to sugest polystyrene cement but that is very runny. Have you tried epoxy resin ? When mixed its a bit like treacle.
Dan,
DLR
www.freewebs.com/dlrail
DLR
- Mrs F Controller
Yes I have tried it and it's great but it does have a runny moment when it starts to cure. I haven't tried Evistick ultimate yet and I spent my lunch half hour in Robert Dyas (not a great place but it is in Loughton and handy for me at work) and read the labels on all the glues and fixatives ie no more nails, Evistick impact etc and they all state not to use with PE AND PP plastics!DLRdan:100673 wrote:I was about to sugest polystyrene cement but that is very runny. Have you tried epoxy resin ? When mixed its a bit like treacle.
Anyone tried a hot glue gun??
Not much will stick polythene and polypropylene ( PE and PP ) , except heat welding, thats why they say don't use them. Polystyrene is very different and many solvents will dissolve the surface, allowing it to bond with another disolved surface as it evaporates. The trick is to use a chemical that will evaporate before it eats further in than just a surface layer. Impact adhesives don't evaporate quickly ( 15 min) so they keep eating into the plastic.
Tbh I'm not sure of the ingredients of Evilstick Ultimate but I suspect it is silicone based and have you ever tried to get silicone sealer off ?!
I wouldnt even think about hot glue on styrene, it will melt.
- Mrs F Controller
Well, I use to love silicone sealant and used it quite a lot but the last time I used it was with the plastic "tiled" roof sheets onto a wood base for the church roof. By a few months later in the garden the wind took the sheets off and the silicone was still stuck to the wood! In fact I stripped the church roof off with my 95 year old mum at Easter! All we used was our finger nails to pick it off in lovely strips from the wood before tiling it properly with slate (see another posting).
Ok have to admit to not being what type of plastic it is but I think you know the stuff anyway. This whole rebuilding exercise this spring is about getting the models sufficiently sturdy enough to be left out until the winter hence the replacing of the plastic roofing and brick sheets as nothing will make it stick to anything for long! The Nissen hut has a rounded 'corrugated iron' roof which is lovely but I am beginning to think I might do better making my own! I have done that with tin foil cooking dishes cut down and put through a paper crimper! We did it 5 years ago to the engine shed and it's still standing! Only trouble is it's hard to make it rounded as it flattens as you bend it!
I think I am becoming obsessed with this! I spent so long looking at the glues in Robert Dyas I think the manager thought I had a solvent problem!
Glues for polystyrene
My mum is only 94,but I might give a goI stripped the church roof off with my 95 year old mum
Lead me not into temptation,for I can find my own way.
- Mrs F Controller
- Mrs F Controller
Thanks for the offer of the screws, most kind. Actually we have boxes if various screws stainless and otherwise mainly used for doing things on the boat! But, yes we had thought of that and I am working on it! Bought today some Evostick epoxy glue especially for plastic! Actually says on it for use with polystyrene etc! Haven't tried it yet as got to work out a plan of action for putting it together if it goes runny! Will let you know and send piccies.bazzer42:100691 wrote:If you can think of a way bending as you go I do have some very small stainless self tappers that could be screwed into the resin using pilot holes. I could send you a few if you think it is feasible. Probably best done in conjunction with some form of glue as well.
- Mrs F Controller
