Using G scale and 16mm/ft buildings together
- andymctractor
Hi,
saw these two houses next to each other and thought that if they were modelled exactly to scale they would look very wrong as if a G scale building were being used next to a 16mm/ft one.
There is no trick photography here. I believe the left house was built 1853 or thereabouts and the right house a little later. However, it looks like the right house has had a relatively modern porch with new size doors to comply with very much later building regs.
Good luck
Good luck
Andy McMahon
Andy McMahon
- andymctractor
I can promise you it isn't faked or photo shopped and neither is it an April fools joke.jim@NAL:98747 wrote:doesn't look right at all looks like its been faked or photo shopped
If you ever come to Beccles, find the level crossing on Ingate and up the hill on the left are the houses in the photo.
Good luck
Andy McMahon
Andy McMahon
- andymctractor
I have to make a mini confession. I did use Photoshop but only to cover up the house number on the right house.andymctractor:98752 wrote: I can promise you it isn't faked or photo shopped
Also, the pictures of The Kent and North Wales Light Railway always make me want another go at indoor detailed modelling. I still want to continue in the garden but there is much satisfying modelling that cannot be done outside. I will probably use smaller scales though. Brilliant railway.
Andy McMahon
Andy McMahon
Thanks for "friendly words" as we say on the continent. Shame that the tree next to the pub is currently stuck into a piece of foam Since I took that pic, I have done the landscaping but I´ve still got a little way to go ...andymctractor:98758 wrote:I have to make a mini confession. I did use Photoshop but only to cover up the house number on the right house.andymctractor:98752 wrote: I can promise you it isn't faked or photo shopped
- andymctractor
I bought a Skytrex yard crane from an O gauge circle exhibition and 16 milled it by replacing the jib from the kit with an extended brass tube from my odds and sods box. I also had to extend the supporting rods on the jib but that was fairly straightforward. It is very convincing.jay1976:98790 wrote:I have a dockside small crane as well but thats O gauge faller crane and bside a loco its a lile small but no noticable
Andy McMahon
Andy McMahon
Photo pleaseandymctractor:98803 wrote:I bought a Skytrex yard crane from an O gauge circle exhibition and 16 milled it by replacing the jib from the kit with an extended brass tube from my odds and sods box. I also had to extend the supporting rods on the jib but that was fairly straightforward. It is very convincing.jay1976:98790 wrote:I have a dockside small crane as well but thats O gauge faller crane and bside a loco its a lile small but no noticable
- andymctractor
Photo please :lol:[/quote]andymctractor:98803 wrote:I bought a Skytrex yard crane from an O gauge circle exhibition and 16 milled it by replacing the jib from the kit with an extended brass tube from my odds and sods box. I also had to extend the supporting rods on the jib but that was fairly straightforward. It is very convincing.
Here is the photo of the Skytrex O gauge crane that has been 16 milled as described above.
This photo would be more useful if a 16mm/ft item were placed alongside it for comparison but this crane after adaptation is similar in proportions to the very nice 16 mm/ft crane available from Back 2 Bay 6.
Hope this helps.
Andy McMahon
Andy McMahon
Here is the photo of the Skytrex O gauge crane that has been 16 milled as described above.andymctractor:98833 wrote:Photo please :lol:andymctractor:98803 wrote:I bought a Skytrex yard crane from an O gauge circle exhibition and 16 milled it by replacing the jib from the kit with an extended brass tube from my odds and sods box. I also had to extend the supporting rods on the jib but that was fairly straightforward. It is very convincing.
[/img][/url]
Hope this helps.[/quote]
I´ve got one of the B2Bay6 cranes too. Just need to build it
- andymctractor
Hi,kandnwlr:98991 wrote:I´ve got one of the B2Bay6 cranes too. Just need to build it :roll:
I wrote an article for Garden Rail mag on my build of the B2Bay6 kit. It is on pages 36 and 37 of the May 2011 edition if you have access to old editions and you want to read my article. pm me if you want some more info.
Originally I had the crane secured to a scrap piece of timber but later bought the grounded van from Swift Sixteen and used the base of that for the crane.
Andy McMahon
Andy McMahon
