Single occilating cylinder loco?
Has anyone got a loco running from a single occilating cylinder? I have a project in mind that this might be the solution for if they can work?
If it can be made full scale it can be made 16mm
My line: http://gardenrails.myfreeforum.org/about7200.html
I've got a dewinton running from a single osscilating cylinder, runs very well. There is video of it on youtube.
Dan,
DLR
www.freewebs.com/dlrail
DLR
Can I get a link to the vid please dan?
Also any chance you could send me some photos of the cylinder, particularly how it's plumbed in and the reverser if I can get my head around a single occilating cylinder then I might manage the small loco I wanted
Issue I need to address is gearing I think....
I made a few videos so i will just post the links. As for gearing and reverse there isnt one, this was my first loco built back when I was 16. It uses a single mamod cylinder direct drive.
http://youtu.be/mvoJ2fixHHk
http://youtu.be/jmKDXwh1rGs
http://youtu.be/JdkjcJap8gw
Dan,
DLR
DLR
- Superbiker_uk
Re: Single occilating cylinder loco?
Thanks for this dan! Is the drive direct from cylinder to the axel? Did you need a flywheel?DLRdan:94373 wrote:I made a few videos so i will just post the links. As for gearing and reverse there isnt one, this was my first loco built back when I was 16. It uses a single mamod cylinder direct drive.
It is direct drive from the cylinder to axle. A fly wheel is not needed as the forward momentum of the engine creates the flywheel effect. I can get you some more pictures of the engine if you like.
Dan,
DLR
DLR
I'd be very interested in more photos of the loco please dan!
I'm guessing it's not the sort of thing you're thinking of, but my single-cylindered geared Regner Konrad is fantastic. OK, it looks a little odd (Vincent is slightly more conventional), but it's powerful, contolable and runs beautifully. If anything I plan to make mine look odder - big headlamps (from my Accy Baldwin), a Swift Sixteen cowcatcher, buckets and re-railing jacks, etc etc...
I'm planning a model of Louisa but trying to get the efficiency required has been proving tricky... That is until someone suggested a single oscillator between the frames. As the most it will ever be pulling is 5 slate wagons it should run fine.
Sorry to be dim, but what (who?) is Louisa? I'm intrigued...LnBmad:94391 wrote:I'm planning a model of Louisa but trying to get the efficiency required has been proving tricky... That is until someone suggested a single oscillator between the frames. As the most it will ever be pulling is 5 slate wagons it should run fine.
- Dr. Bond of the DVLR
- Retired Director
This is Louisa:
She is miniature in comparison to other quarry hunslets. Scaled down she's about 120mm long!
Dan,
DLR
DLR
- DaveWatkins
Best of luck with Louisa. If you can find any reference to John Foulds's loco they might help with your project - he built quarry Hunslets in 16mm scale driven by a single cylinder oscillator.
Here are a couple more videos of single cylinder oscillator locos:
A vertical boilered DeWinton like loco, 3/8th bore double acting cylinder with meccano gears.
http://www.youtube.com/watch?v=jf3eb8OX0ME
and
Another vertical boiler, this time a Sentinel like loco using a single acting cylinder with gears bought from a 16mm Association second hand stall.
and
Dave
Think you've pasted the same link twice Mr Watkins
Dan,
DLR
DLR
- DaveWatkins
