Baking painted metal parts with a domestic oven
Lner fan Sam
I have got some loco body parts that I am planning to paint with halfords car paints. As a primer I will be using upol acid etch 8 and was wondering if it is ok to bake the parts with this acid etch in the kitchen oven? If so does anyone have any tips on how long the parts should be in the oven for and at what temputure?
Thanks in advance.
Thanks in advance.
MAJOR RULE 1:
ONLY DO THIS WHEN 'ER INDOORS OR THE DOMESTIC AUTHORITIES ARE NOT PRESENT as it can stink the house out!
MAJOR RULE 2:
Only have the oven running at its minimum temperature - it's all that's needed.
MAJOR RULE 3:
Bake for short periods and keep checking - half-an-hour should be more than enough
MAJOR RULE 4:
Remember the bits will be HOT!!
MAJOR RULE 2:
MAJOR RULE 3:
MAJOR RULE 4:
DolwyddelanLightRail
MAJOR RULE 5:MDLR:94016 wrote:MAJOR RULE 1:
MAJOR RULE 2:
MAJOR RULE 3:
MAJOR RULE 4:
Don't accidentally put them under the grill, and please don't ask how I know this!
LnBmad
- Keith S
It works, though. After painting my roundhouse kit engine, I noticed the boiler wrapper was taking on a nice, less "model"-y looking texture while the cab and tender were not. I realized that this was due to the heat of the boiler "baking" the paint, so I put the whole engine in the oven for an hour at a low setting. Now the paint looks the same all over the engine, and seems harder and less rubbery.
Don't do it while there are any women at home. For some reason they don't understand how necessary it is.
METHSSNIFFER
Baking in respect of two pack yes cos heats needed for the reaction between the resins. With halfords paint heat the metal parts with a hairdryer and lightly fan as you are spraying this ensures atomisation.
I wouldn't advise baking anything in an over other than food.
A microwave does make a good spraying booth with a turntable though I have an old one with the drive disconnected and rotate by hand.
Bake at a low temp by all means for two pack and enamel. Watch out with a fan oven as it will blow any small bits of muck on to your new paint.
I have warmed brass kits up on a radiator before spraying and that can work quite well.
I like the idea of the microwave spray booth. does this mean you can do a 3hr job in 10 mins?
