Where can you buy reeeeaaaallllyyyy cheap 32mm gauge track?
Woodfields Light Railway
Post by Woodfields Light Railway » Tue Dec 10, 2013 7:01 pm
Okay, we'll maybe reeeeaaaallllyyyy cheap track doesn't exist, but where can I get some on a budget? Any ideas?
Thanks...
"So, when is this newfangled railway coming?"
"When we have enough money..."
"Where is this money coming from?"
"Havent thought that far..."
Post by Big Jim » Tue Dec 10, 2013 7:16 pm
Ebay for secondhand, or the forum For Sale section. Trouble is nothing is really cheap.
Red plastic Big Big track does appear on ebay but it is not really suitable but it is the cheaper end.
Trackshack on the Isle of Man is about the cheapest for new peco that I have found. Around 90 quid for 1doz yards.
Post by Woodfields Light Railway » Tue Dec 10, 2013 7:23 pm
*faints*. Gosh, that's a lot. I suppose I have quite a small garden though
Post by Woodfields Light Railway » Tue Dec 10, 2013 7:24 pm
Is tenmille any good?
Post by bazzer42 » Tue Dec 10, 2013 7:26 pm
In the last 12 months I have picked up some tenmille 45mm for less than a quid a foot. A rare bargain perhaps but was from a dealer not ebay.  There are some short lengths but ideal for sidings.... keep your eye out.  I have also done well with a job lot on ebay that was a mixture of tenmille and lgb.
I am not a proud man and am happy to live on second hand track. Tenmille 45mm doesn't seem universally popular!
Bazzer42
jay1976
Post by jay1976 » Tue Dec 10, 2013 9:32 pm
All my track so far is secondhand with plenty of life left in it... Cant afford new track so bargains have to be searched for..so far 12 lengths of flexitrack and 6 metre lengths of tenmile along with about 5 metres of offcuts of tenmile track with a few curves in it A bit of mamod track and a huge oval of big big red track which is ok if you paint it black
steamyjim
Post by steamyjim » Tue Dec 10, 2013 10:16 pm
I have gone for secondhand track on my line. I use a mixture of Peco and Tenmille SM32. The first batch of Peco was bought from the forum, I then bought a small bundle of Tenmille at a car boot sale for a few quid. The secondhand stalls at shows are always worth looking at - I bought another bundle at the Exeter GR show.
My latest big batch came from an advert of track for sale - I ended up with 3 points and about 50 yards of track for £120. Assuming a tenner each for the points - that comes to about £1.80 a yard.
Bargains are out there - you just have to wait for them!
Enginehouse
Post by Enginehouse » Tue Dec 10, 2013 10:39 pm
Woodfields Light Railway:93434 wrote:Is tenmille any good?
I use Tenmille 32mm exclusively with no problems whatsoever, but I don't lay track on the ground, its all raised on board or ally bridgework. I also run LGB/Piko in the same way and never have any problem with either sets of trackwork.
Cheers
Roy H
Graff B.
Post by Graff B. » Wed Dec 11, 2013 7:32 pm
I bought some really cheap wooden sleepered, brass railed track, which was cheap because the chairs and sleepers were past it. Cleaned up the rail and resleepered it with tenmille sleeper strip. Worked out about half the price of new tenmille track. Only problem was finding correct fishplates.
Lner fan Sam
Post by Lner fan Sam » Wed Dec 11, 2013 8:15 pm
Be careful about buying track on eBay as sometimes it can be damaged when being post or the seller just isn't letting up on the real condition of the track.
When buying second hand track I would personally get it from shows, that way you can "inspect" the track for any damage.
my first live steam engine build thread:
http://gardenrails.myfreeforum.org/about6685.html
Sam Wake
TonyW
Post by TonyW » Wed Dec 11, 2013 8:34 pm
I love it. Most of mine is 20 years old and on its third railway!
TommyDodd
Post by TommyDodd » Wed Dec 11, 2013 11:16 pm
There are other methods if you're sufficiently practical and equipped.
1) It is possible to just buy flat-bottom rail and make up your own track- cut sleepers on a table saw and spike rail down with gimp pins or similar.
2) If you can weld, I have known someone build a complete railway from 12mm black mild steel strip, long bits on edge for rails welded to short flat bits for sleepers. Regular application of oil stopped the rail-heads rusting, but when the sleepers rusted they just looked more natural.
Well, now we know the buffer-stops work! (Heard at 2013 "Longest Day" solstice steamup)
Post by Woodfields Light Railway » Thu Dec 12, 2013 7:41 am
I'm a orangotan compared to skilled crasftsmen, so will probably need ready built stuff
Post by Big Jim » Thu Dec 12, 2013 10:25 pm
Hey, even us Orangs have our skills. (Family joke after my son pointed at a picture of one and shouted "Daddy")
Track building is not that difficult. It just takes a little planning and care. Points can be a bit tricky but If you can get a plan its is just like building a jigsaw. Soldering can be tricky at first but with a little time and the right materials and it is easy enough to master.
Post by Big Jim » Fri Dec 13, 2013 9:30 am
Just had a flick through the 16mm society handbook and there is an article about building track in it. You might find it handy if you go down this route.
LnBmad
Post by LnBmad » Fri Dec 13, 2013 6:42 pm
If your working on a tight budget work out the track plan before you purchase anything! That way you can by only the parts you need. eBay can be your friend but decide what you want first.
If it can be made full scale it can be made 16mm
My line: http://gardenrails.myfreeforum.org/about7200.html
Post by Woodfields Light Railway » Sun Dec 15, 2013 7:13 pm
It's ok everyone... ( I know you were worrying. Hee hee) forget this thread. I have found some cheapo track on trackshack
Post by Narrow Minded » Sun Dec 15, 2013 7:16 pm
Woodfields Light Railway:93703 wrote:It's ok everyone... ( I know you were worrying. Hee hee) forget this thread. I have found some cheapo track on trackshack
There you go, another success story ~ it really is amazing what a little personal research can do ;)
