dehumidifier problems
Sylvian Tennant
Post by Sylvian Tennant » Mon Dec 02, 2013 1:17 am
I while back I bought a Challenger Dehumidifier I bought for collecting water for my loco.
It worked for about two months and then suddenly stopped collecting water, as the warranty looked a bit dodgy I bought another one and exactly the same thing happened to it. As any had any similar problems?
I have cleaned them out monthly but to no avail.
Post by Big Jim » Mon Dec 02, 2013 8:15 am
Have you checked any air filter on it sometimes these are well hidden. Also they don't seem to like too cold a room.
Sylvian Tennant
Post by Sylvian Tennant » Tue Jan 14, 2014 12:16 am
The filter is right at the top and I darn't take it apart.
It's not leaking anything (not even water) and blasting out cold air. I know recently that we have had a really cold spell but the house I live it is quite warm.
I managed to clean out the filter with the hoover again and I'm trying it out again but it still seems to be dry.
rebelego
Post by rebelego » Tue Jan 14, 2014 8:22 am
The air might be dry. Common during winter. Here I use a humidifier during winter, so the furniture and my wooden floor don't dry out. :)
Busted Bricks
Post by Busted Bricks » Tue Jan 14, 2014 12:31 pm
Is it a compressor type and can you hear the compressor turn on? We have a dehumidifier where the starter capacitor on the compressor melted. I bought a new cap on Ebay and it works fine again.
Sylvian Tennant
Post by Sylvian Tennant » Fri Feb 28, 2014 12:07 am
I might try that, however I ended up buying another in Argos for just under £100 and this one appeared to be better and took in alot of water. However, tonight when I went to turn it on... the fan doesn't appear to be spinning. I only bought it Sunday, as well!
I'm not having much fun with these things.
Big Al
Post by Big Al » Fri Feb 28, 2014 12:21 pm
I had an expensive dehumidifier that worked well for quit some time then no water , I believe it done it's work and kept the house dry have not used it for some time I will plug it in and see if it gathers any water from the air again , They can only fill with water if the air is damp.
Post by jim@NAL » Fri Feb 28, 2014 4:44 pm
if the room is to hot or cold the dehumidifier will not work .
Sylvian Tennant
Post by Sylvian Tennant » Sun Mar 02, 2014 10:37 pm
cheers for the advice chaps.
At the moment there seems to be little shortage of water where I currently am.
I think it was something to do with the fan motor in the end as I took it back to Argos under guarantee and the replacement as a free rolling fan where as the other one was quite stiff.
