Lynton and Barnstaple carriage kits, a joint venture
LnBmad
Post by LnBmad » Fri Aug 16, 2013 10:34 pm
As some of you will know I'm a bit of a fan of the L&B. specifically the gorgeous carriages that they ran. Having a young family has meant that the wonderful offerings from accucraft have unfortunately been out of my price range (and in the wrong colours). I was lucky enough to get hold of a tenmille full 3rd kit and that satisfied me for a little while. Once completed though this kit had left me wanting more. I began looking at various options (plasticard/ plywood scratch builds, grs kit, etc) but none of these options were as exciting to me as what came next.
Searching through the forum I came across a thread about laser cutting where mike aka WVLR had mentioned to someone that he might be able to help with some parts. A swift pm resulted in a simple plan to have a go at producing some carriage sides. As I began to draw out the sides in 16mm scale I started to think about what other parts would I find awkward to make at home, again a quick email and mike agreed that we would have a go at some other parts.
What happened next developed VERY quickly. Mike informed me that he wanted to produce some parts that he could sell and I wanted carriages. The idea again evolved that together we would produce the drawings and then mike would manufacture the basic parts for ALL 17 carriages. A busy week or so of scaling and drawing and then converting to cad and here we now find ourselves. This morning the postman delivered to me the first 4 carriages in kit form.
Here are the photos of the 4 kits that arrived.
Carriage 1&2
Carriage 3&4
Carriage 7,8,9&10
Carriage 11,12,13&14
I cannot wait to get these kits put together!
jay1976
Post by jay1976 » Fri Aug 16, 2013 11:06 pm
you will be buzy then for some time.
LnBmad
Post by LnBmad » Fri Aug 16, 2013 11:09 pm
3 more carriages to draw out and then they are all done. Then it's a case of putting them all together. I can do roughly a complete carriage per week with all the detailing when scratch building so these should be a little quicker.
Post by Andrew » Sat Aug 17, 2013 3:06 pm
Those look great! A carriage a week is incredible! I reckon on 6 months each for mine, although most of that time is usually spent finding lost bits and tools due to the muddle I work in...
Good luck with 'em,
LnBmad
Post by LnBmad » Mon Aug 19, 2013 11:59 am
So here's the work done on carriage 1 so far.
The chassis is drying for carriage 3, and I'll be building the 2 remaining chassis tonight.
Really excited for the next parcel from mike, should have the bogies and the internal partitions.
More photos to follow.
The Denying Dutchman
Post by The Denying Dutchman » Mon Aug 19, 2013 1:12 pm
Looking great sofar. You're clamping "tool" is very clever, simple but effective. Much better than 20.000 clothespins and a few dozen of clamps!
Paul
LnBmad
Post by LnBmad » Mon Aug 19, 2013 10:47 pm
Carriage 1 now with roof. Note carriage 7 has been started under the books ;)
LnBmad
Post by LnBmad » Fri Aug 30, 2013 10:42 pm
Bogies and pivot for coupling fitted, being test run to check for any issues. Click on link below :p
http://i1365.photobucket.com/albums/r76 ... 94dc6b.mp4
LnBmad
Post by LnBmad » Thu Sep 05, 2013 8:16 am
Beading applied on one side. Really happy with the finish so far!
Post by Andrew » Thu Sep 05, 2013 9:16 am
LnBmad:87908 wrote:Beading applied on one side. Really happy with the finish so far!
I'm not surprised - looking great!
Post by Narrow Minded » Thu Sep 05, 2013 10:40 am
Really nice! :D
Post by laalratty » Thu Sep 05, 2013 8:54 pm
Looking very good
METHSSNIFFER
Post by METHSSNIFFER » Thu Sep 05, 2013 11:17 pm
L and B White metal bogies from Tenmille will finish it perfectly. They do the transfers as well as the correct style brass door handles amd lamptops. What height are your coach sides?
LnBmad
Post by LnBmad » Thu Sep 05, 2013 11:21 pm
The bogies mike has made look good being honest! The door vents I am making a master part and will then cast my own in resin. Door handles ill buy in. Lamp tops I will machine my own am then cast them in resin aswell.
LnBmad
Post by LnBmad » Thu Sep 05, 2013 11:40 pm
What measurement do you want of the carriage sides METHSSNIFFER? If its the actual side height (not from rail) it's 98mm.
METHSSNIFFER
Post by METHSSNIFFER » Thu Sep 05, 2013 11:49 pm
Thats 6' 6" 98mm, just got a tenmille kit L and B on the shelf, thats 90mm do you know the correct height of the prototype.
LnBmad
Post by LnBmad » Thu Sep 05, 2013 11:54 pm
565mm x 98mm
LnBmad
Post by LnBmad » Thu Sep 05, 2013 11:56 pm
I scaled up from the measured and drawn book as well as looking at the tenmille kit I built. Should be right +/-1mm
METHSSNIFFER
Post by METHSSNIFFER » Fri Sep 06, 2013 12:03 am
Thanks for info
METHSSNIFFER
Post by METHSSNIFFER » Fri Sep 06, 2013 12:51 am
Drawings
Click to download file
From these drawings I've measured height at approx 6' with the solebars being 6".
