Ragleth reversing lever
Vapouriser
Having bought some more up to date radio control I have started fitting it to my Ragleth. But- i need to remove the spring from the reversing lever , or at least loosen it as its too strong for the servo. I cant unscrew it. Looks like a rivet. Do I really have to saw it off?!
Vapouriser
Its a circlip. It just fell apart and dissappeared! But I can see the groove. Back to your tea chaps!
Vapouriser
Found the bits. Nearly finished. Tried to use a chain drive to regulator as it needs such small opening to go full speed but no space. Is there , I wonder, a ready to fit regulator for Ragleth with a finer thread. I have a feeling its going to be a challenge as it is.
- Gremlin
Mattyrallye
I don't think you can put a finer thread regulator in on an accy loco as the turret is on thread and isn't detachable. Roundhouse have got round this by making the turret detachable with a thread so you can swap a manual regulator for a (as Dave has explained) much wider pitched thread to allow greater movement in a short throw.
I am glad your not putting radio on the reverser on this though. I don't agree with that method of radio control. It just wastes steam in my opinion.
