Hi Guys,
I've just bought all the bits to radio control my Caradoc, but being new to radio control, i'm not sure if I can set the throw of the servos "electronically" or if I can only adjust the throw using the linkages?
I have a Planet T5 transmitter and receiver.
Any help gratefully received!
Radio Control Servo adjustment
Busted Bricks
- Chris Cairns
The Planet T5 is a basic entry level 2.4 GHZ transmitter, so it does not have the facility to adjust servo throw electronically on the transmitter.
So you are limited to using a combination of the holes in your servo arm and control horn linkage. Although it is for an aeroplane there are some useful illustrations in this article - http://www.modelairplanenews.com/blog/2 ... up-servos/
