Track!
SapperAnt
Track!
Post by SapperAnt » Mon Jun 03, 2013 8:52 pm
I am flabberghasted by generosity.
Jenny, the very very sprightly 90 year old over the road learned via our neihgbours that like her late husband I have a garden railway. Since his death it has lain derelist. Upon learning of my interest, however, she gifted me over 25 metres of track and two pairs of points, two kit-built foot bridges, a signal and what else she can find (which includes a huge pile of 16mm today etc).
The track a Peco 0 guage: Is it possible to run live steamers on it?
Jenny's late husband obviously did because he had a Lady Anne (kit built), which Jenny is holding on to but she would like to see it run again. :shock: :shock:
pauly
Post by pauly » Mon Jun 03, 2013 9:40 pm
Yes you can run steamers on Peco
A steam propelled life-style.
SapperAnt
Post by SapperAnt » Mon Jun 03, 2013 9:42 pm
Cool!
The only problem Ive got with the 0-gauge compared to SM32 is the rail profile - I can't join the two. :evil: not that Im complaining. I await with wonder, and trepidation, what will emerge next from Jenny's shed.
Post by tom_tom_go » Mon Jun 03, 2013 10:15 pm
She probably has no idea how much the stuff is worth.
Might be a kind gesture to offer her some money.
SapperAnt
Post by SapperAnt » Mon Jun 03, 2013 10:20 pm
Yeah I'm fealing a bit...... "concerned" shall we say about this gift. She said it was no use to her and was just taking up space in her shed. Some of the track is damaged - there's about 30 metres in total - but the vast majority is useful. :| :|
LnBmad
Post by LnBmad » Mon Jun 03, 2013 10:32 pm
Can match it to sm32 if your careful where you join it.
SapperAnt
Post by SapperAnt » Mon Jun 03, 2013 10:35 pm
Useful to know. Care to explain?
LnBmad
Post by LnBmad » Mon Jun 03, 2013 10:49 pm
Get the track levels matched and cut the rail straight. Don't use fishplates and double screw both ends down. Using this method I have joined Mamod track with peco sm32 with no issues.
LnBmad
Post by LnBmad » Mon Jun 03, 2013 10:58 pm
Please excuse quality of photo as its dark outside but here's how I did it:
SapperAnt
Post by SapperAnt » Mon Jun 03, 2013 11:11 pm
You must be a mind reader! I was just going to ask for a picture of how you'd done it!
Fantastic!! :D
LnBmad
Post by LnBmad » Mon Jun 03, 2013 11:15 pm
SapperAnt:84399 wrote:You must be a mind reader! I was just going to ask for a picture of how you'd done it!
Fantastic!!  :D
As you can see I ended up filing them to get it smooth but it works a treat. Never had a derailment. Should work the same using o gauge track. If. Needed to electrify it all I'd do is solder a small wire between the two pieces ad away you go :)
SapperAnt
Post by SapperAnt » Tue Jun 04, 2013 11:30 pm
Cool! thanks
upon closer inspection this old chappies line was track powered and every single joint was soldered. When the track was lifted the fishplates were just snapped. So I suspect rather a lot of de-soldering required.
Jenny - the old lady - suggests there might be more bits and pieces. And also an old O gauge Triang loco (Big big Train????)
