Post
by tom_tom_go » Sat May 18, 2013 2:36 pm
Been playing about with this scratch build for a while, however, I wanted to weather the wood so it looked like untreated timber that has been in the elements for years:
No Indian ink or expensive washes used here. Instead, I filled up a small cup of vinegar and then left some wire wool in it over night. Then, in the morning I diluted the solution with water using the same quantity as I had used with the vinegar and then just painted it on.
Tom
Dr. Bond of the DVLR
- Retired Director
Post
by Dr. Bond of the DVLR » Sat May 18, 2013 5:23 pm
Did the vinegar go slightly green? I've tried various things for making weathering solutions and it didn't work terribly well for me. Most successful one so far is my Jar of rust. Salt water and wire wool....
Big Al
Post
by Big Al » Sat May 18, 2013 5:28 pm
I like that a nice effect on the timber.
Post
by tom_tom_go » Sat May 18, 2013 5:47 pm
Mr. Bond of the DVLR:83598 wrote:Did the vinegar go slightly green? I've tried various things for making weathering solutions and it didn't work terribly well for me. Most successful one so far is my Jar of rust. Salt water and wire wool....
I have had the solution going for a few days now and it has not gone green. The wire wool will disintegrate within 24hrs so best to remove it before this happens as I had to sieve the solution it a few times to remove the bits.
- Retired Director
Post
by Dr. Bond of the DVLR » Sat May 18, 2013 5:54 pm
Wonder what on earth went wrong for mine then! What colour did your vinegar go then?
Post
by tom_tom_go » Sat May 18, 2013 7:34 pm
I used white vinegar. Did you use brown malt vinegar?
- Retired Director
Post
by Dr. Bond of the DVLR » Sat May 18, 2013 7:39 pm
no, I used white as well!
Post
by tom_tom_go » Sun May 19, 2013 8:11 am
My solution stayed clear although you can leave the wire wool in for a darker browner colour.
Post
by tom_tom_go » Sun May 19, 2013 1:17 pm
Does anyone have a photo of any prototype of where the split pin chain goes on the wagon itself please?
I need to trim the chain, however, not sure where to attach it to on the wagon.
Cheers!
Tom
Post
by MDLR » Sun May 19, 2013 4:09 pm
I'd suggest somewhere near to (if not on) the top screw on the rack, where you pin the brake down.
Dannypenguin
Post
by Dannypenguin » Sun May 19, 2013 7:00 pm
Where did you get the brake gear bits/bits on the chassis above the axleboxes/cosmetic brackets connecting bufferbeam to chassis?
Thanks in advance.
Post
by Chris Cairns » Sun May 19, 2013 10:18 pm
As Brian has said in the standard gauge world the chain would be secured at the top of the brake handle quadrant. Just make sure the chain is long enough so you can put the pin into the bottom hole on the quadrant.
METHSSNIFFER
Post
by METHSSNIFFER » Sun May 19, 2013 10:27 pm
I would shape the brake shoe with a file a bit
Post
by tom_tom_go » Mon May 20, 2013 12:38 pm
Dannypenguin:83656 wrote:Where did you get the brake gear bits/bits on the chassis above the axleboxes/cosmetic brackets connecting bufferbeam to chassis?
Thanks in advance.
Hi Danny,
IP Engineering make all the cosmetic bits and the axleboxes are from an IP laser cut kit which I have added rivet detail.
I prefer metal axle boxes, however, I thought I might as well build something out of it as I had the bits
Thanks for the pointers on the chain. I have done this now so will paint it all up and post a picture another time.
Tom
Dannypenguin
Post
by Dannypenguin » Mon May 20, 2013 4:35 pm
tom_tom_go:83690 wrote:
Hi Danny,
Thanks
Its looking great!
Post
by tom_tom_go » Sun Nov 23, 2014 7:42 pm
Post
by bazzer42 » Sun Nov 23, 2014 8:24 pm
I like that Mr TT.
daveyrd11
Post
by daveyrd11 » Sun Nov 23, 2014 8:40 pm
Very nice job, like it
Post
by Soar Valley Light » Mon Nov 24, 2014 6:26 pm
Absolutely superb. Thanks for the inspiration.
Post
by tom_tom_go » Sat Mar 14, 2015 5:40 pm
