radio control in larger scales?
- Keith S
I was just idly wondering, is there such a thing as a garden railway in, say 3 1/2" gauge or larger without riders, and instead radio controlled?
It's probably a lot of fun to ride behind your little locomotive, but sometimes watching them I feel like the models look really silly with a 1:1 scale old man perched on top of the locomotive tender. Does anyone ever run locomotives like this with no driver and instead install radio controls in them like the little ones? I can't see why you couldn't do it. You could make a jolly good garden railway in this scale and have fun watching the train from your garden chair, and then as the mood strikes you, you could hop on for a ride or not, depending on your mood. Also you wouldn't need to sit on the engine, you could drive the train from a few wagons back, and enjoy the view of the locomotive and some proper scale wagons in front of you.
LlanpwllBrynwyn
invicta280
Shouldn't be a problem as long as the train remains in sight of the operator.
Here's some 1:1 scale R/C. Admittedly only shunting.
http://youtu.be/TIbF2tsbrYE
TommyDodd
Lner fan Sam
DolwyddelanLightRail
- Chris Cairns
I've also seen full size shunter radio controlled diesels with Tranz Rail in New Zealand, and on the Harzer Schmalspurbahnen in Germany.
Regarding controlling gas valves an electronic control was developed by Cheddar Models which adjusted the burner based on the boiler temperature. That was taken over by Stuart Models and of course the price increased significantly - http://www.stuartmodels.com/accessories ... as%20Valve
Alternatively there are gas attenuating valves which are operated by a diaphragm which is connected to the boiler pressure.
Peter L
It's extremely common here in the US - the technology was pioneered by mines and steel furnaces but has now spread - it's not uncommon to see 18,000 horsepower of remote-controlled mid-train helpers out west.Chris Cairns:83856 wrote:I've also seen full size shunter radio controlled diesels with Tranz Rail in New Zealand, and on the Harzer Schmalspurbahnen in Germany.
Users browsing this forum: No registered users and 48 guests
