Running boards
MuzTrem
Running boards
I'm trying to decide how to finish the running boards on my new brakevan...based on photographic evidence, it seems that some railways leave them unpainted, others leave them matt blacl. Which do people think looks best? Or can anyone suggest any alternatives?
peterbunce
re stepboards on Guards vans
Hi,
Looking through my Midland Wagons book most of the stepboards seem to be a lightish colour. this I would take as being a earth colour, on top of the unpainted boards.
I now model 1880's Colorado and there the walkway on top of the boxcars was unpainted wood as painted wood could in certain conditions be slippery, especially when wet.
The same I think would apply here in the UK, the roughness of the boards providing a better grip.
Yours Peter.
Yours Peter.
- GTB
Re: Running boards
Here in OZ the VR left footboards and shunters steps unpainted on the top surface for safety reasons. The supports, toe stop, sides and underneath the footboard were painted underframe colour. Over time the wood weathered to the usual silvery grey.MuzTrem:80372 wrote:I'm trying to decide how to finish the running boards on my new brakevan...based on photographic evidence, it seems that some railways leave them unpainted, others leave them matt blacl. Which do people think looks best? Or can anyone suggest any alternatives?
I use stripwood on a brass frame for steps, so when painting the van I just mask the top. When the rest of the paint is dry, I just dry brush it with a matt mid-grey paint. If you make the steps out of metal or plastic, you'd need to paint the top surface a suitable wood colour, then dry brush it with grey to simulate the grain of weathered wood.
Somewhere I've also seen wooden footboards with a metal insert along the front with a diamond tread pattern to reduce wear and presumably also the risk of a slip.
Hello!
Personally I paint them matt black over a grey primer and then attack them with fine sandpaper - just a little, to represent some normal wear and tear, or harder, so that the bare wood shows through in places to represent heavier use or a longer period since overhaul/repaint. I like the way it suggests the carriage/brake van sees real use - it works particularly well on carriages with continuous running boards where you can attach the bits below the doors and leave the rest almost unscathed...
IrishPeter
I have always tended to paint them matt black. The anti-slip element was often supplied by a cast iron edge to the footboard, though I have occasionally run across black paint with coarse sand thrown on it or mixed with it to provided a better grip. OTOH, if I was building US stock with roof walks I would leave those unpainted.
On carriages that have not seen the paint shop for a while a moderate application of sandpaper under the 1st class doors, and a heavy one under the 3rd class doors is always good.
Peter in AZ
Peter in AZ
MuzTrem
Thanks for the feedback guys. I have decided to go for matt black with "weathering" in the right places. Accordingly, I have painted the board and tried rubbing then down with fine sandpaper under the doors. I am not entirely happy with the result so may have another go with a needle file when I have time.
