Engine interfering with RC control
benchmark
Has anyone experienced this phenomenon before, i just noticed that one of my engines interferes with its RC control in the form of occasional flutters seen on the servos. It only happens if the engine is in motion on live steam. I have tried 2 different RC 2.4 Ghz brand radios systems with the same results. Any idea how to solve this problem?
Thanks.
Thanks.
benchmark
Busted Bricks
I often work on R/C models right next to my router - not a single blip of interferences. I think it is a myth that they interfere with 2.4GHz R/C systems.MDLR:75495 wrote:Are you anywhere near a wireless broadband router? They work on 2.4 gig, too..........................
Metal against metal is bound to create some "noise". Try moving the RX around a bit and check all connectors are good and clean.
benchmark
it will be low voltage on your batary pack or a lose conection ,if your sevos and recever are powered by a little battary back that takes aa battays try buying really chap aa battays the ones you see in a back of 12 for like 2 or 3 pounds these last a lot longer for some reason i used to use them in my rc cars to power the handset and the sevos etc .
