Link & Pin...
AFGadd
Link & Pin...
Post by AFGadd » Thu Sep 20, 2012 10:24 pm
I've been building a coupling system that will allow my stock to travel freely on my railway.
A view of the back of the Prince quickly reveals the amount of swing from centre. Although the locos freely traverse the 2ft 6in curves & pointwork, keeping the stock following was more of an issue....
The obvious soloution is to use the Link & Pin coupling system that comes with the AnDel kits.
AnDel even supply these Link & Pin couplings separately, with a little planning they fit very well to my own build stock.
However, there's nothing "Off the Shelf" to fit Roundhouse locos so I've built my own.
These are made from a combination of styrene & brass.
I'm reasonably happy with the results, I think I can improve on the looks but the coupling works over my trackwork perfectly.
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Thu Sep 20, 2012 10:35 pm
An excellent result and it looks great too!
AFGadd
Post by AFGadd » Thu Sep 20, 2012 10:38 pm
Mr. Bond of the DVLR:75070 wrote:An excellent result and it looks great too!
Thanks, the next loco to tackle is a R/H Penrhyn Hunslet.
However, I'm not so sure the chunky feel of these couplings will look so good on the finer lines of a saddle tank?
Dwayne
Post by Dwayne » Fri Sep 21, 2012 1:32 am
I plan on going L&P with my equipment in time. Rivets make good pins. :)
AFGadd
Post by AFGadd » Fri Sep 21, 2012 3:32 pm
Dwayne:75077 wrote:Rivets make good pins. :)
I am trying out larger pins (note the huge loop pin in the image), my fingers aren't that small any more (to many years of manual labour) and I can't be fiddling with tweezers just to couple up....
Another thing I've discovered is the large link-loop I've made. This also makes coupling to another vehicle much easier as the link-loop will travel right up into the body of the coupling and allow the pin to simply drop.
jabsteam
Post by jabsteam » Mon Oct 01, 2012 2:34 am
Andrew, is your longer link soldered closed?
If not, do you think it will pull apart from a train load?
Adam R
Post by Adam R » Mon Oct 01, 2012 3:19 pm
jabsteam:75363 wrote:Andrew, is your longer link soldered closed?
I built some Corris loco couplings, by soldering a brass plate to some bits of chain, it only came loose recently, after a derailment and a very stuck coach it finally gave in after about 3 years of hauling stuff, including Llechfan garden railways biggest train... the chain link has to break the solder then unfold itself, None of my other chain is soldered shut, and I have no problems with it breaking open. there only little really, and tend to roll alright.
Annie
Post by Annie » Mon Oct 01, 2012 9:10 pm
If you make links from galvanised steel wire they won't pull apart under load. I use galv steel wire to make coupling links on the Kotanga Tramway using beading pliers to form the links. The other advantage is that galv steel wire is way cheaper than brass.
Image[/img]
Spule 4
Post by Spule 4 » Mon Oct 01, 2012 11:30 pm
Annie:75395 wrote:If you make links from galvanised steel wire they won't pull apart under load.  I use galv steel wire to make coupling links on the Kotanga Tramway using beading pliers to form the links.  The other advantage is that galv steel wire is way cheaper than brass.
Image[/img]
Annie, would you mind posting a 3/4 view from slightly above of that coupler, looks like an interesting design! :D
AFGadd
Post by AFGadd » Tue Oct 02, 2012 2:45 pm
Hi, sorry for not posting sooner I've not been near a PC and I hate posting using my phone and predictive text...
I have soft soldered the link (brass) ends together. I didn't do so for reasons of strength but for ascetic reasons.
I had cut the ends of the link with side cutters and the join looked appalling to my eyes. I had the blowtorch in my hand and I thought why not...
I certainly don't envisage any problems with link strength on my line as I'm very unlikely to run long trains.
Annie
Post by Annie » Tue Oct 02, 2012 11:39 pm
Spule 4:75408 wrote: Annie, would you mind posting a 3/4 view from slightly above of that coupler, looks like an interesting design! :D
No problem :D
Spule 4
Post by Spule 4 » Wed Oct 03, 2012 12:26 am
Thanks, reminds me a bit of the Darj type. Well done.
