I'll upload a diagram/ emmet style drawing tomorrow but has anyone ever laid a trough between the tails and mounted a pop pop boat boiler in between a set of wheels for power? The idea came to me today out of the blue... Should I be worried?
POP POP POWER
- Dr. Bond of the DVLR
- Retired Director
POP POP POWER
Pop pop power
tuppenced
- Retired Director
- GTB
I'd call it a steam/hydraulic linear motor.......Mr. Bond of the DVLR:74747 wrote:A canal with rails on each side...
The vehicle would need to be very light, with low friction pinpoint bearings. It may work , although the motor in the average pop-pop boat is rated in fractional mosquito power.
There is an article on building a pop-pop boat by Marc Horovitz here, which looks like it might be worth a try using the motor part of the design.
http://www.nmia.com/~vrbass/pop-pop/buildpop.htm
I look forward to the video.
Pendo Pilot
Sounds like a lot of work for little reward, however if you are going to lay stuff in the 2ft/2ft 7(whatever broad gauge is) then why not try Brunels atmospheric railway design? Using a hoover for propulsion, although points could be complex & getting a good seal might be as tough as the real thing.
- Retired Director
TommyDodd
It might be easier if you were to separate the prime mover from the payload...
THOUGHT EXPERIMENT:
Take a small circular lake (use a washing-up bowl or similar). Place a large-ish number of pop-pop boats (8 or 12) thereon. Connect them up in a "wheel" arrangement so they all face in the same direction (clockwise or anticlockwise). Connect the "hub" of the wheel to a drum. Connect the drum to a loop of cord for cable haulage. Attach rail vehicles to cord, set fire to pop-pop boats, sit back and watch...
THOUGHT EXPERIMENT:
benchmark
