A place for discussing diverse methods of powering locomotives, such as Internal Combustion, Wind, etc...
Crackingjob
Post
by Crackingjob » Thu Aug 16, 2012 10:45 pm
Being out of things for a while and with too many half done projects, thought I needed a quickie project to get back in to things and finish half done projects
So.....quick clockwork locos
WINKSTEAD HALL meant to be the BR nationalised version of Bessie from Chigley...but is more Emett
OUTBID will be my reaction to loosing out on a clockwork loco chassis at the auction at the 16mm AGM this year
Early days yet
As it arrived from E Bay
The build starts...nice cab
Forgot to photograph before I did too much
Need to space out the tender from the loco
Post
by MDLR » Thu Aug 16, 2012 11:11 pm
Next year's MOTY entry??
williamfj
Post
by williamfj » Fri Aug 17, 2012 9:15 am
Like the look of it so far!
Crackingjob
Post
by Crackingjob » Tue Sep 04, 2012 2:33 pm
Some movement on Winkstead Hall which is begining to look more rustic than Emettish
Simple card with embossed rivets and some track pins in the water tank
The whistle on top of the cab (which I attempted to also add embossed rivets)
is a map pin with a chunk cut out to be a whistle.
Just need to add detail to the smoke box door and a crew, lick of paint and couplings sorted out
between to loco and tender (which needs coal)....and there we are done ...ish!!!!
It runs well on the old deeper corse O scale track but bounces on the modern Peco SM32 track, so need to
trim the flanges a little.
Pictures to follow as system would not allow me to attach at the moment
Crackingjob
Post
by Crackingjob » Sat Sep 15, 2012 9:32 pm
I seem not at present to be able to upload pictures so here is the link to my postings on AWNUTS Again
http://whymsical.com/index.php?topic=842.0
You will have to scroll down to see the later pictures on page1
You will also see some fantastic models by Peter Butler
Hi managed to get computer fixed...more pictures to follow
Crackingjob
Post
by Crackingjob » Tue Dec 04, 2012 1:55 pm
railwaygardener
Post
by railwaygardener » Thu Jan 03, 2013 8:16 pm
Excellent work, and just to encourage you further, here is another Emett-inspired layout built for the 2011 Corris exhibition by a local resident.
Rather alarmingly, he said it would have to be demolished soon after to make room for his next creation.
