SM32 track roller gauges.
kimstation
Post by kimstation » Sun May 20, 2012 11:21 pm
Hi,
I am about to start building some SM32 points/turnouts and need to buy some roller gauges.
Marcway are the obvious suppliers, but unfortunately theirs are not available at the moment.
Does anyone know anyone else who makes SM32 track roller gauges please?
Cheers
Kim
jabsteam
Post by jabsteam » Mon Oct 01, 2012 3:48 am
Late to the ball, now, but I just ordered a set of 4 from C&L Finescale in Bristol.
jabsteam
Post by jabsteam » Thu Oct 11, 2012 1:46 am
I've just received the roller track gauges from C&L Finescale, and to my disgust they will NOT work with Code 215 rail. :cussing:
The little grooves are WAY too narrow to fit over the head of the rail.
No mention at all what size rail these are to be used on. What a waste of time and money...
dws
Post by dws » Thu Oct 11, 2012 7:10 pm
jabsteam:75689 wrote:I've just received the roller track gauges from C&L Finescale, and to my disgust they will NOT work with Code 215 rail.  :cussing:
Did you ask if they work with Code 215 rail ?
jabsteam
Post by jabsteam » Fri Oct 12, 2012 3:28 am
No I didn't. I figured 32mm track gauge would at least be compatible with Peco Code 200 rail.
Looks like these gauges are for O gauge Code 148 rail.
jabsteam
Post by jabsteam » Sat Oct 13, 2012 10:35 pm
So where can I get a set of 32mm track gauges for Code 200+ rail?
Or do all of you on that side of the pond use Peco ready made track exclusively?
