Another of my new products has just landed. It is a plate of brass strips for detailing wagons. Each single strip, (8 on a sheet) is .5mm thick by 4mm wide and about 275mm long with a half etch dot on one side for punching into a rivet.
There are also two more strips at .5mm thick by 8mm wide and about 275mm long. These strips have a half etch line going through the middle for folding into an 'L' section. It also has two rows of half etched dots for punching.
I use a metalsmith rivet punch, but you can just as well use a blunt nail in a drill press with the depth stop setup.
Now you can get a fantastic look with very little effort. I think the price will be about £13 a sheet.
Thanks :D
Rob.
