Merlin Locomotive Works - Mamod Loco Information
- Superbiker_uk
Here is the information (all circa 1985) supplied with the Merlin Radio Control Kit
Merlin catalogue scan of Mamod Information
Merlin Gas Burner
Merlin Gas Burner
- laurence703
- Superbiker_uk
If you ever need to replace the o-rings on the control needle of the Merlin gas burner tank you need some of these o-rings:
http://www.ebay.co.uk/itm/370859623567
3mm ID 1mm C/S
3mm ID 1mm C/S
- Chris Cairns
- Superbiker_uk
Yes that is correct. I think the gas jet was blocked and the operator carried on opening the valve and had a little accident. In use you do not need to open the valve more than one complete turn - the control is not very fine on these burners.Chris Cairns:91108 wrote:Over on the other forum was it not a Moderator that had a close call when his Merlin gas valve unscrewed completely out with the burner already alight?
- Chris Cairns
Finally found the Topics in myfreeforums after struggling with their search facility.
Merlin Gas Burner Warning - Another discussion had the flame length at 3', but this original one had it at 6' and a fair list of injuries sustained - http://modelsteam.myfreeforum.org/ftopi ... -asc-0.php
Improving a Merlin Gas Burner - Here Tony Bird discusses replacing the original bronze mesh with nikchrome mesh to improve the radiant performance of the burner - http://modelsteam.myfreeforum.org/ftopi ... -asc-0.php
Nikchrome mesh is difficult to get a hold of in the UK so I used Stainless Steel mesh instead, and the improvement is very good.
