Question....
jez kirkwood
Question....
Post by jez kirkwood » Tue Dec 06, 2011 10:10 pm
Has anyone tried turning the reverser control the other way up, shortening the lever (so it doesn't foul the track!) and running a linkage back to the cab under the footplate? Was just thinking it might be worth a try and wondered if it's been done...........
DolwyddelanLightRail
Post by DolwyddelanLightRail » Tue Dec 06, 2011 10:45 pm
When I get the chance I'm going to do something simular, so the loco has an in cab reverser, but leave the lever as it is as have a bell crank on the running plate linking them
Post by Narrow Minded » Tue Dec 06, 2011 10:53 pm
DolwyddelanLightRail:62553 wrote:When I get the chance I'm going to do something simular, so the loco has an in cab reverser, but leave the lever as it is as have a bell crank on the running plate linking them
I've seen that done before, and I've gotta say that the "under the footplate" solution sounds neater! :D
Post by DolwyddelanLightRail » Tue Dec 06, 2011 11:00 pm
It does sound better, but after all sorts of faffs I've had with Britomart's steam pipe, I prefer having things that are easily accessible, so I don't have to take the whole bloody thing apart for it not to work properly again 'cause I needed to screw a lose screw back in etc
Isn't there a picture on the mamod forum NM of an in cab reverser some like that? or was that on here? can't remember now :lol:
Post by DolwyddelanLightRail » Tue Dec 06, 2011 11:04 pm
*edit*
Yes it is on the mamod forum, the loco "DIANA" which had been modded to a saddle tank, it's on page 3 of "Running MSS loco with spirit burner", near half way down the main locomotives & railways page
jez kirkwood
Post by jez kirkwood » Wed Dec 07, 2011 12:35 am
Thanks Chaps,
That's really interesting, hadn't thought of doing it like that........
have to give this some serious thought.
Cheers
Jez
Post by -steves- » Wed Dec 07, 2011 7:51 am
Well i have no idea who did this conversion, but it works extremley well. I can supply more pictures if needed, these are some that were taken a while back. Essentually, the reverser has no lever at all, its been drilled and threaded rod (long bolt) has been used to adapt it to take the ball in the picture. The rod that runs down the loco has a C cup on it and it all works very well indeed, and can not be seen topside.
Please ask for more pictures if you would like them, however, I will not be able to do any till next Monday at the earliest. Its a cracking little mod though.
bessytractor
Post by bessytractor » Wed Dec 07, 2011 11:16 pm
I've certainly flipped it over the other way up before with no ill effect.
jez kirkwood
Post by jez kirkwood » Wed Dec 07, 2011 11:28 pm
Had an idea at work today and have just done a mock up version to see if the concept works. The idea is to use a length of brass tube which runs along the top of the frame with a length of piano wire inside. I annealed a piece of brass tube then shaped it and drilled a small hole in the frame and reversing lever
This looked like it might just work so I clamped the tube to the frame and..............
http://www.youtube.com/user/steamblacks ... ature=mhee
:D :D :D :D
Post by DolwyddelanLightRail » Wed Dec 07, 2011 11:48 pm
Now that I like!
dougrail
Post by dougrail » Thu Dec 08, 2011 12:16 am
Same, how does that work then?
jez kirkwood
Post by jez kirkwood » Thu Dec 08, 2011 7:29 am
dougrail:62635 wrote:Same, how does that work then?
It works like a bike brake cable - I used to use this system for point control on small scale model railways, hopefully I'll do a bit more work on it today.............
Post by Narrow Minded » Thu Dec 08, 2011 8:34 am
Very clever! :D I've tightened my reverser up so much to stop steam leaks that I doubt I'd get the piano wire to "push" it over! :?
jez kirkwood
Post by jez kirkwood » Sun Dec 11, 2011 5:34 pm
I'm in the process of building MK 2 and realised that having never run a Mamod I don't actually know which way the reverser works :oops: so could one of you lovely people tell me which way the loco should go when I push the lever over to the left (looking from the front).
Cheers
Jez
DLRdan
Post by DLRdan » Sun Dec 11, 2011 6:36 pm
It should go backwards but doesnt really matter.
jez kirkwood
Post by jez kirkwood » Sun Dec 11, 2011 8:17 pm
DLRdan:62976 wrote:It should go backwards but doesnt really matter.
Thanks Dan - matters to me as I want to rig the cab lever so that when I push the lever forward it goes forward etc. could be a little confusing otherwise :D
laurence703
Post by laurence703 » Mon Dec 12, 2011 4:27 pm
Having seen your brilliant idea, I have just done the same to my loco, but I have a small problem... How does one attach the copper pipe to the front end of the loco?
I was thinking a few drops of glue from a hot glue gun but would this not melt the paint or actually melt from the heat?
Post by DolwyddelanLightRail » Mon Dec 12, 2011 4:55 pm
it would most likely melt from the heat, as the front on the loco becomes rather hot!
spooner
Post by spooner » Mon Dec 12, 2011 6:19 pm
I would bend up a bracket and screw to the front casting.
jez kirkwood
Post by jez kirkwood » Mon Dec 12, 2011 7:17 pm
spooner:63029 wrote:I would bend up a bracket and screw to the front casting.
This is more or less what I'm planning - I'll post some pics when I've actually done it :D
