In my quest for technical details for B Wagons, I came across a handy little application that is extremely useful for calculating scale measurements.
You input the measurement (choosing the scale ratio, so if its the actual length, you use the ratio 1:1) and then choose the scaling ratio for your output measurement. So obviously for 16mm/1ft scale you put 1/19. Measurements can be inputted in metric or imperial, and you can mix and match for input and output. It also allows you to work out the ratio for scales too. I'm not too good at describing this kind of thing, but it is very handy tool when scratch building if you are basing your model on a prototype!
Does anyone know if there is a way of sharing it with other members?
Scale Calculator program
ACLR
