Accucraft Edrig Radio Control
RSB
Post by RSB » Sun Jan 09, 2011 8:02 pm
I have a Edrig, which as we speak is manual control, is there a "off the shelf" kit for radio control, that I can fit to it?
I see on the frames under the footplate there is a cut out for a switch, so I guess the receiver would live?
Hope someone can help
Cheers
Rob
andysleigh
Post by andysleigh » Mon Jan 10, 2011 1:24 am
i dont think theres an off the shelf kit that enables an edrig to be converted, but some companies/ people do offer services to covert it for you. chuffed 2 bits, ACME,  and i think a couple of members on ehre offer that kind of service.
Normally Edrigs only have the reverser rc'd, which acts as a regulartor and reverser,  the servo is mounted in the side tank, a link arm from the servo to the reverser, whic already has a hole in it for an arm,   and as you said, the reciever, switches and batterys in the box under the loco.
It shouldnt be to hard to nock up at home if you if you have a few tools. and can eb done from a typical RC pack
MRail
Re: Accucraft Edrig Radio Control
Post by MRail » Mon Jan 10, 2011 9:01 am
[quote="RSB:46399"]
Rob[/quote]
Rob, my S/H Edrig came with a retro fitted R/C on the regulator.
I added my own R/C to the reverser.
The switch and batteries go under the cab, as you mention.
The reverser servo goes in the RH side tank, holes are pre-drilled.
Wiring is fed through various holes down to the switch.
The operating rod goes to the reverser lever - there may be a hole already drilled - you need to remove the centering notch spring.
In my case, the regulator servo is glued to the cab floor.
A suitable regulator arm is made by Chuffed2bits.
As yet I have no means of sending pics.
If you'd like to email direct... mrail(at)live.co.uk
Rob G
Madog & Mersey Railway (SM32)
Sir haydn
Post by Sir haydn » Mon Jan 10, 2011 11:14 am
RC fitting in an edrig is fairly simple.With such large side tanks there is plenty of hiding space. As andy says I can offer the service to do this converison, or offer my help and advice should you fit it yourself
RSB
Post by RSB » Mon Jan 10, 2011 3:56 pm
Thank you gents for your help, I shall now look into this further and see what I can do! :D
Mr ACME
Post by Mr ACME » Mon Jan 10, 2011 7:27 pm
MRail:46419 wrote:
Rob
Ahem, thanks for the non-plug, Rob. After all the favours I've done you as well. GRIN.
Radio control fitting and bits are available from me at ACME Engineering, including the aforesaid regulator servo arm.
Any rumour of our demise is wildly exaggerated. We designed the Accucraft RC systems and started working closely with them when they started as Marches Models.
Best
Mike Ousby
sid8
Post by sid8 » Wed Nov 14, 2012 10:53 am
Some companies/ people do offer services to covert the off the shelf kit for you but I dont think theres an off the shelf kit that enables an edrig to be converted.
Sid
Nitrotek
Mr ACME
Post by Mr ACME » Wed Nov 14, 2012 4:05 pm
sid8:76767 wrote:Some companies/ people do offer services to covert the off the shelf kit for you but I dont think theres an off the shelf kit that enables an edrig to be converted.
Sid
Nitrotek
When I first started fitting RC to Accuraft engines in 2001, I also made available a DIY fitting kit. The problem was that despite assurances from buyers that they had a degree of competence in working on engines, the reality was totally different. I found that the level of support they needed meant that it was uneconomical to continue.
Best
Mike Ousby
