16mm Headlamps
MamodFan
16mm Headlamps
Post by MamodFan » Sat Jan 01, 2011 12:19 am
First of all, HAPPY NEW YEAR! :)
Seccondly, Does anyone know of anywhere i could buy 16mm healamps? :)
taliesin001
Post by taliesin001 » Sat Jan 01, 2011 1:04 am
I use the chuffed 2 bits GWR lamps for the earl, quite expensive but look nice, although these have a bracket on the side so only really suitable for W&L stock. I think they do others though.
MTA
Post by MTA » Sat Jan 01, 2011 10:19 am
Chuffed 2 Bits do them: http://www.chuffed2bits.com/page31.html
PPS sells the C2B ones, and GRS sell lamps too. If you want non-working lamps, Brandbright is your best bet.
peterbunce
lamps
Post by peterbunce » Sat Jan 01, 2011 10:35 am
Hi, DJB have some new white metal ones at the following link
http://www.djbengineering.co.uk/new.html
Post by MDLR » Sat Jan 01, 2011 1:18 pm
Of course, any of the cast non-working ones can be drilled out from the back to accept an LED, if you don't mind fixed lamps.
I don't know about anybody else, but I find the batteries in the Chuffed 2 Bits lamps last next to no time - anybody else have the same problem?
taliesin001
Post by taliesin001 » Sat Jan 01, 2011 1:29 pm
Yep, mine have almost run out and I've hardly used them.
MTA
Post by MTA » Sat Jan 01, 2011 7:11 pm
I've got 1 head and 1 tail L&B style lamp from C2B, and have used them several times over two years and they are still on the same battery they were supplied with.
mhlr
Post by mhlr » Sat Jan 01, 2011 11:19 pm
Both of mine have run out, only used them once or twice for short periods.
MoelygestLR
Post by MoelygestLR » Thu Jan 06, 2011 11:33 pm
roundhouse get there supply from C2B i think. I have two sets of head and tail and although they dont last long, think its great the way they can always be on the head and tail of a train, even if not switched on. most of us run through the day anyway!
METHSSNIFFER
Post by METHSSNIFFER » Fri Mar 04, 2011 1:38 am
Best lamps money can buy c2b supplied by Finescale Engineering where quality is excellence. No better place to shop go to Chuffed to Bits ! and you will be!
Keith S
Post by Keith S » Fri Mar 04, 2011 2:47 am
Give it a rest :roll:
