DolwyddelanLightRail
Post
by DolwyddelanLightRail » Sun Jul 11, 2010 10:28 pm
Matt
Post
by Matt » Sun Jul 11, 2010 11:34 pm
Looking good.
May I sugest that you buy some track that's more to scale.
Pendo Pilot
Post
by Pendo Pilot » Sun Jul 11, 2010 11:41 pm
Always good to get started, good luck with the build.
Post
by Narrow Minded » Mon Jul 12, 2010 12:18 am
Well hey!
I was wondering when you were going to get around to it! Well done you
At this stage, I'd not worry too much about what track you're using (ie use what you've got!) but
maybe think about burying the sleepers in the (now to be permanent
) ballast.
Post
by DolwyddelanLightRail » Mon Jul 12, 2010 8:46 am
Thanks guys!
I am going to be using a fair bit of my older stuff (the standard gauge stuff) but i am also getting some SM32 track as well from peco (hopefully in the not too long distanct future!)
What i'm going to try to do this summer is just get the basic bits of track down at least, and if i have enough spare time, maybe i'll think about little bits and bobs like ballasting!
Dr. Bond of the DVLR
- Retired Director
Post
by Dr. Bond of the DVLR » Mon Jul 12, 2010 9:40 pm
Great progress! I need to start now and catch you up I suppose!
mhlr
- Retired Director
Post
by mhlr » Mon Jul 12, 2010 11:20 pm
Regarding the track problems, I know that SOME stuff for Sm32 doesn't like the 0 gauge fine stuff, as the flanges hit the tops of the chairs due to the rail depth - my mate Ben has some. So that's worth thinking about for future purposes.
What about using the 0 gauge stuff in sidings and stuff like that where it isn't going to be run on as much? Then use the Sm32 on the main running line.
Post
by DolwyddelanLightRail » Tue Jul 13, 2010 8:42 am
I'm going to use as much finescale in sidings etc as pos, but i am going to have to use some on the mainline to try to keep costs down (the main strech is longer than i expected!) I'll also upload the track plan soon (most likely tonight)
Post
by DolwyddelanLightRail » Fri Jul 23, 2010 10:13 am
Well, it's been a while and nothing has happened since! (mainly cause of the blumin rain!
) but here is a track plan of the layout:
The dotted lines are the edges of paths and it also shows the layout of the main station (Dolwyddelan) with the run round loop and siding.
Sir Clothem Cap
Post
by Sir Clothem Cap » Tue Jan 11, 2011 7:46 pm
Looks like a good plan. Why the extra height of the bricks?
taliesin001
Post
by taliesin001 » Tue Jan 11, 2011 8:34 pm
wuld it be possible to incorporate some more curves? Just thinking it may get a bit boring with a huge long straight.
Post
by Narrow Minded » Tue Jan 11, 2011 8:38 pm
I
nearly had a return loop and never came up with a final solution to how I was going to operate the turnout.
How are you planning on tackling it?
Oh, and never mind the rain, get out there ya wuss! I've been out in it and remodelled the top end of my line and squeezed a new station and town in, so when it
stops raining I can get the detailing done
Post
by DolwyddelanLightRail » Sat Feb 04, 2012 12:04 pm
Steven.T
Post
by Steven.T » Sat Feb 04, 2012 4:33 pm
What is the track, Peco?
I'm suprised it doesn't melt/burn if Britomart comes to a stop above it
Post
by DolwyddelanLightRail » Sat Feb 04, 2012 11:14 pm
Yep Peco finescale stuff, needs replacing really! and nah, it stays in tact quite well surprisingly!
Post
by DolwyddelanLightRail » Fri May 04, 2012 8:08 am
Well, there's been very little progress on the line, mainly because some Blackbirds decided to build a nest above the line, so was instructed to not go out and run trains incase it scared them away. Luckily they've given up (nothing to do with me, honest!) and ran the first train on the line in a while, and what better to run was Snowdon, which needed one last test run before it was "signed off" after it's "B" exam, and here's a small taster (and also the first video for the line!) of the loco working hard!
<iframe width="560" height="315" src="
http://www.youtube.com/embed/5iSIbo9UVr4" frameborder="0" allowfullscreen></iframe>
Post
by Narrow Minded » Fri May 04, 2012 8:57 am
Cheers James - are you selecting "Use Old Embed Code" from the YouTube menu??
Post
by DolwyddelanLightRail » Fri May 04, 2012 9:26 am
I was using the code at the bottom of the video under "Share", but strangely enough it worked on the mamod forum!
Post
by Narrow Minded » Fri May 04, 2012 9:44 am
Try "Share", "Embed", then make sure you select "Use Old Embed Code".
Copy the code and paste it into here (don't use URL)
