Powering playmobil chassis
biggerdom
Post by biggerdom » Sun Jun 27, 2010 9:59 pm
Hi all,
Does anyone think this would power a playmobil chassis ok?
Cheers.
tuppenced
Re: Powering playmobil chassis
Post by tuppenced » Sun Jun 27, 2010 10:20 pm
biggerdom wrote:Hi all,
Cheers.
May I ask:
- what is "this"?
- do you mean the old track powered chassis or the new radio controlled chassis?
- and a name to reply to ?
I have happily powered the old type Playmobil locomotives with 4 AA alkaline cells. They went slowly with a short train, but that's what I needed when my kids were very small.
The standard power source for the radio type is 4 AA cells. If you lose the original holder or want to rearrange it an ordinary holder works just as well.
David 1/2d
biggerdom
Post by biggerdom » Sun Jun 27, 2010 10:22 pm
Doh! forget to post the link :roll:
http://shop.huntersystems.co.uk/loco-mo ... -142-p.asp
I mean the old track powered one, i was thinking of using a 9 volt battery or will that not have to 'muscle'
Looking to pull either 5 flats, or 2 bogie coaches..
tuppenced
Post by tuppenced » Sun Jun 27, 2010 10:47 pm
It looks as though it will.
The little boxy PP3 batteries are quite amazing despite their very low capacity. I haven't actually used them on a Playmobil chassis, but they will run a (similar but more efficient) LGB chassis pulling a couple of LGB 4-wheeled coaches for maybe 10 minutes.
So could be good for a couple of wagons for 5min - assuming you have the chassis it's worth a try with just a battery before investing in a controller.
Substituting disposable Lithium PP3s will increase the duration a lot more than it increases the price nowadays.
http://tinyurl.com/2f3ybsg
[Don't mess with rechargeable lithium batteries unless you know what you are doing - balanced charger, fuse, and fire bucket to drop your engine in ;-)]
David 1/2d
Crackingjob
Post by Crackingjob » Mon Jun 28, 2010 11:41 am
I have a Faller loco, that was 12v track fed which I converted to 9v battery and fitted a cambrian controller and it runs very well and scale speed. Space was tight and I had to add weight.....Its easy and cheap to do
So I would think you will have no problem with the playmobil chassis
Thanks for the link....just what I am looking for......another possible is to look at Timpton for thier controllers
Crackingjob
tuppenced
Post by tuppenced » Mon Jun 28, 2010 12:06 pm
Crackingjob wrote:I have a Faller loco, that was 12v track fed which I converted to 9v battery
Apart from the massive difference is load and in motor current, yes. D
