My secret project is revealed
steamyjim
Post by steamyjim » Thu Feb 07, 2008 3:50 pm
Not garden railway, but model steam ;)
Over the last few months me and my grandad have been building a 'secret project' in the workshop
Well here it is.
It was first revealed at STIA
Its a generating plant built using my old Wilesco D20 engine.
I intend to fit it with a gas burner after i have sorted out the wiring :wink:
If anyones interested ill post some more information about it :?
Overall view
Water tower
Generators
Control panel
Fan
Condensing stack
Power plant-a Wilesco D20 engine
Engine...again
Pump-with handle on
Pump-with handle off
Condense container
Oil can THE SPIDERMAN POSTER IN THE BACKGROUND AIN'T MINE :lol: !!!!!
Gas tank I intend to fit
Gas burner I intend to finish and fit
Post by laalratty » Thu Feb 07, 2008 5:09 pm
Thats brilliant :shock: :shock:
steamyjim
Post by steamyjim » Thu Feb 07, 2008 5:38 pm
Thanks!
mhlr
Post by mhlr » Thu Feb 07, 2008 5:40 pm
I want that, send it to this address:
Peter Clarke
I want it now,
Give the engine to me Str.,
I love it,
Please Please ville,
IW4 NT1
lol, nah, very nice inteed SJ!
steamyjim
Post by steamyjim » Thu Feb 07, 2008 5:44 pm
I got mostly enough bits and peices to make another 2 :lol:
mhlr
Post by mhlr » Thu Feb 07, 2008 5:48 pm
well, tempting... but have I got enough to spare on toy steam... no :( Only Garden Railways ATM.
steamyjim
Post by steamyjim » Thu Feb 07, 2008 6:26 pm
I might build one with a Stuart Turner engine to provide lighting to the WLR :D
mhlr
Post by mhlr » Thu Feb 07, 2008 6:41 pm
steamyjim wrote:I might build one with a Stuart Turner engine to provide lighting to the WLR :D
Thats a good idea. I had the thought for my line to make a steam generator to light my mine, and put the engine in a tin mine engine house!
SillyBilly
Post by SillyBilly » Thu Feb 07, 2008 6:47 pm
That's a beautifel engine Jim :) !
steamyjim
Post by steamyjim » Thu Feb 07, 2008 6:47 pm
I got 2 Stuart D10 2 cylinder engines.
Im thinking about putting both of them into a engine house direct coupled to a generator (stepper motors) powered by a bank of 2 or 3 Stuart Babcock boilers.
This would produce about 15 volts each engine ;)
steamyjim
Post by steamyjim » Thu Feb 07, 2008 6:48 pm
Thanks Will :D
ACLR
Post by ACLR » Thu Feb 07, 2008 8:03 pm
:shock: wow thats great mate love it
ptlrcecil
Post by ptlrcecil » Thu Feb 07, 2008 8:32 pm
Here ill trade you the plant for a bag of ferrets and a ball of fluff in my pocket.
Matt
Post by Matt » Thu Feb 07, 2008 8:34 pm
Thats an interestiong machien there. How much power does it produce?
steamyjim
Post by steamyjim » Fri Feb 08, 2008 10:07 am
ptlrcecil wrote:Here ill trade you the plant for a bag of ferrets and a ball of fluff in my pocket.
:lol: :lol: :lol: :lol:
steamyjim
Post by steamyjim » Fri Feb 08, 2008 10:08 am
Matt wrote:Thats an interestiong machien there.  How much power does it produce?
Thanks! Each dynamo produces about 2volts. Aulthough with a full head of steam at full tilt they produce around 5 volts each ;)
riveresk
Post by riveresk » Fri Feb 08, 2008 7:52 pm
Great stuff, very impresive. :shock: :)
steamyjim
Post by steamyjim » Sat Feb 09, 2008 11:20 am
Thanks :D
steamyjim
Post by steamyjim » Sat Feb 09, 2008 11:22 am
Heres some more info for anyone who is interested...
The base
The base is made from about 1/2" MDF (sold in metrick) then extra sections of the same MDF are mounted underneath to make it stand above the ground. Sprayed titanium
The engine
The engine is a Wilesco D20. I stripped it down,removed the paint. Resprayed it-heat resistant for firebox and section of base underneath firebox. The rest of the base is gloss black. Flywheel and engine sub base hand painted.
Water tower
Gas tank from blow torch. Top cut out. Hole drilled in bottom with a machine peice of brass in it. The brass is fitted onto a peiceof copper tube. A second hole is drilled to the side and a fitting is soldered in. The copper pipe fits over a stand bolted to the base. Sprayed black. Inside grey
Water pump and stand
The water pump i had in the workshop. Mounted on a base of alluminum. Sprayed black.
Generators
The generators are made from 2 Meccano 3V motors. Mounted on a alluminium base. 2 bits of plastic tube connected the 2 with a shaft and pulley in between. Sprayed all over black. Alluminium base mounted onto another mini MDF base (sprayed titanium) with holes slotted in to enable adjustment.
Lamps
The lamps are made from copper tube bent with a washer soldered in the end containing a LED. Then soldered to a base that is bolted (removable though) to the MDF generator base. Lamps sprayed all over black.
Condensing stack
2 bits of steel from a bathroom handle thing splied togethor.Copper pipe soldered into it to take the exhaust in. Brass top on top. Fitted into a machined brass stand/tank. Tank has a valve on it to enable any condense to run out through a pipe
Control panel
2 bits of U alluminium section with holes drilled and milled to fit switches and meters in. 2 straicht sections of alluminium bolted to the side to hold it together.
Fan
Alluminium machined to a taper. Hole drilled down middle (to fit wire) Motor mounted on top with fan. Thread in bottom of alluminium bolted to base. Motor sprayed black
Wiring
All wiring is underneath base
Heres a diagram
Oil can
Scutliffe oil can sprayed black
Condense pot
Cashew nut tin. Sprayed black. Inside sprayed grey
Users browsing this forum: No registered users and 59 guests
