J.C
made-in-england
J.C
Post by made-in-england » Sun Jan 24, 2010 9:47 pm
Just finished the loco kit I got for xmas...
Was a IP dotti but I moved the exhaust to the top and the air filter to the side but prior to the pic it fell off :( It is my first attempt at weathering anything and I dont like what ive done so Ill repaint it and try again I think. As for its name.. the colour I used was JCB yellow :lol:
And I also done a penryn officals coach too..
Will
PCLR
Post by PCLR » Sun Jan 24, 2010 9:49 pm
very nice form what i can see its a bit out of focus
made-in-england
Post by made-in-england » Sun Jan 24, 2010 9:53 pm
Tis, I had a better camera but it broke and this was the only one I could afford at the time :(
PCLR
Post by PCLR » Sun Jan 24, 2010 9:56 pm
ok fair point what are them kit like to put together
made-in-england
Post by made-in-england » Sun Jan 24, 2010 9:57 pm
Quite good ... I didint have any problems and im an incompetent tit
PCLR
Post by PCLR » Sun Jan 24, 2010 10:05 pm
i would say that pratist makes perfect
mhlr
Post by mhlr » Sun Jan 24, 2010 11:44 pm
nice one Will! Yes, it's out of focus and that, but try a bit of light on it, that helps ;)
I'd paint the rivets yellow, as they wouldn't be left black. You could also try some orangy rusty paint and just very lightly make rust runs down from the rivets and stuff :P
Post by Narrow Minded » Mon Jan 25, 2010 11:01 am
I'd agree with Pete about the rivets and the rust streaks.
Also, a "top tip" I use (from 00 modelling days) is to work from a photo if possible. It doesn't have to be the same loco/wagon etc, just something similar but in just about the same level of neglect that you're wanting to model.
You can see then just where the muck accumulates, paint fades, rust builds up etc and copy that rather than "make it up"
Mix dry bushing with thin washes for different effects and just keep at it. Like PCLR says - practice makes perfect! :D
PS. Looking forward to a finished shot of the coach!
made-in-england
Post by made-in-england » Thu Jan 28, 2010 1:45 pm
Just to let you know ive painted the rivets back to yellow and IMA they look loads better. Ive tidied up the electrickery bits. Got some iron filings so plan to add some REAL rust! Have also had thoughts about using coffee stiriers to go across the seat? thoughts?
Will
Post by Narrow Minded » Thu Jan 28, 2010 1:54 pm
Sounds cool - picture ?????
SillyBilly
Post by SillyBilly » Thu Jan 28, 2010 5:19 pm
How fine are the iron fillings? Really you only want them as fine as dust.
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Thu Jan 28, 2010 5:43 pm
Correct and you want some vinegar, water mix to mixem with and brush em on with.
Coffee stirrers out to make an OK seat.
They are OK for nearly everything. I made a 16mm scale sledge out of coffee stirers the other day...
made-in-england
Post by made-in-england » Thu Jan 28, 2010 7:34 pm
the filings are stuff I pulled out the bottom of dads bench grinder and seem to be quite fine.. I can but try :)
DolwyddelanLightRail
Post by DolwyddelanLightRail » Thu Jan 28, 2010 7:54 pm
made-in-england wrote:Quite good ... I didint have any problems and im an incompetent tit
Your not the only one!  :lol:
Nicely done by the way! :D
made-in-england
Post by made-in-england » Sat Jan 30, 2010 11:51 pm
JC takes the first train across WWW rails in 2010 :D
