Merddin Emrys
Post
by Merddin Emrys » Sun Jan 10, 2010 3:20 pm
Dr. Bond of the DVLR
- Retired Director
Post
by Dr. Bond of the DVLR » Sun Jan 10, 2010 4:45 pm
Blimey that looks well made, have a hunt for grub screws. It looks as if the wheels and valve geared have been soldered onto thier axils. Why do you want to dismantle the rear axil anyway?
Merddin Emrys
Post
by Merddin Emrys » Sun Jan 10, 2010 5:26 pm
I can't see any grub screws although the crank pins screw in, the cranks look to be glued in place. I'm not keen on the plastic gears, the gear on the axle is plastic, the last green gear on the right does not mesh correctly either. It's in my head that a replacement axle with worm and wheel in metal would be better, or do plastic gears last well?
mhlr
- Retired Director
Post
by mhlr » Sun Jan 10, 2010 6:37 pm
It makes me wonder why someone who made such a nice model decided to make it just electric...
DolwyddelanLightRail
Post
by DolwyddelanLightRail » Sun Jan 10, 2010 6:53 pm
mhlr wrote:It makes me wonder why someone who made such a nice model decided to make it just electric...
Same
SillyBilly
Post
by SillyBilly » Sun Jan 10, 2010 6:58 pm
Because there is a lot more to steam engines than just cutting some bits of steel.
It's a lovely model Andy, it's going to be a challenge getting that motor sorted, do you have a motor for it yet?
Post
by Narrow Minded » Sun Jan 10, 2010 8:05 pm
That looks like a cracking project Andy, should be a beauty when it's finished - keep us posted.
It's too difficult to tell from the pic's quite how, but if it went together in the first place, rest assured that with a bit of care and patience it'll come apart.
(voice of experience having first of all persuaded my GVT tram to part with its originally fitted Lima chassis then separating it from the IP budget chassis that I'd fitted to battleship specification!!)
MTA
Post
by MTA » Sun Jan 10, 2010 9:14 pm
Andy,
If the gears aren't meshing properly to begin with then they will wear out quicker than correctly meshing gears. So best sort that out.
Plastic gears will last well, assuming that they are properly lubricated using plastic tolerant oils or grease. But metal will always last longer than plastic...
Sir haydn
Post
by Sir haydn » Sun Jan 10, 2010 9:30 pm
looks to me like a DJB build that wouldnt steam so was made electric. have you cheaked the cylinders to see if this may be the case? I could be wrong
Merddin Emrys
Post
by Merddin Emrys » Sun Jan 10, 2010 9:52 pm
Sir haydn wrote:looks to me like a DJB build that wouldnt steam so was made electric. have you cheaked the cylinders to see if this may be the case? I could be wrong
Sadly no it's not DJB, that would have been very lucky for the sixty odd pounds I paid for it
Merddin Emrys
Post
by Merddin Emrys » Sun Jan 10, 2010 9:55 pm
SillyBilly wrote:Because there is a lot more to steam engines than just cutting some bits of steel.
there was no motor with it, I remember seeing a combined axle / motor assembly in a 16mm or Garden Rail mag around a year ago which may be useable, just been looking but can't find the right mag!
Merddin Emrys
Post
by Merddin Emrys » Sun Jan 10, 2010 9:57 pm
MTA wrote:Andy,
thats what worries me about using whats there now!
METHSSNIFFER
Post
by METHSSNIFFER » Sun Jan 10, 2010 11:36 pm
Why would someone go to all that trouble with building a loco to such detail then stick an electric motor in it. Thats a piece of model engineering surely its intention was steam with perhaps a osmotor maybe! I would fit a mamod boiler in it pot fire it like Mr Bailey has done at East Mids ! Have you heard of Paul Millington!
I think those gears were meant for something else!!
Sir haydn
Post
by Sir haydn » Sun Jan 10, 2010 11:58 pm
Martin, the guy who owns Atropos models has found a supplier of small strong motors which im sure have metal gear boxes. Its probly worth giving him a ring and asking. he has used one to motories one of his small corris coaches to make it look like a horse drawn tram car.
Endless, Nameless
Post
by Endless, Nameless » Mon Jan 11, 2010 2:13 pm
The gearing looks very half baked compared to the rest of it, I'm wondering if the loco was bought more- or- less in it's current state and the gearing fitted by a later- possibly less competent- owner.
Merddin Emrys
Post
by Merddin Emrys » Mon Jan 11, 2010 2:35 pm
It was 2 years ago when i bought this (for around £60) I contacted the seller about the construction and this was his reply.....
'Hi Andy, Pleased you are happy with your loco and thanks for the positive feed back. I think I started the loco late seventies or early eighties when I got quite interested in narrow gauge railways. The wheels are turned from cast iron bar, the saddle tank is made from an oil tin and the frames and valve gear etc from steel that was salvaged from some redundant machinery, the rest is fabricated from brass sheet, bar and tube as required. At this point I had my mid life crisis and left off railway modelling for a while and started doing stupid things like cycling all over the place, I'm back on track now (pardon the pun) but now model 7mm BR. so that's the reason for selling the SM 32 stuff.
I'm happy the loco has gone to a good home and hope you have hours of enjoyment from it.
You live in Wales and near Boston Lodge, that's like winning the lottery!
Kind regards and all the best for 2008.
Cliff'
I recall he also had another loco for sale (which I spotted too late to buy which was a Talyllyn or Corris engine (memory fade!) also electric, track powered by a centre stud pick up arrangement
Endless, Nameless
Post
by Endless, Nameless » Mon Jan 11, 2010 2:55 pm
Ahh, fair enough. He's certainly done a nice job of the motion work!
Post
by Narrow Minded » Wed Apr 21, 2010 12:27 am
From memory, that gearing looks like it's from a Bachmann "Big Hauler" - anyone positively confirm or dismiss this?
