Britomart
DolwyddelanLightRail
Britomart
Post by DolwyddelanLightRail » Sat Dec 26, 2009 11:17 am
As some of you may know, I am currently overhauling my Golden Jubilee Mamod, H.G.Butler, now in the overhaul process, I had to swap the jubilee mamods chassis with my MSS "Britomart" (which I originally bought to put H.G.Butler into preservation.) so I could steam the chassis without damaging any of the paintwork
Britomart has now recently failed (as in been dragged down with H.G.Butler) and now she's really in bits, I was wondering of making a few "adjustments" to her. Heres a pic for people who don't know:
(Back end)
Now I know some people may contradict me in saying "The Real Britomart is light blue" (or something like that) that is a future project (the main reason why I named it britomart is becuase the mamod whistle reminds me of britomart). What I am thinking of doing is painting the inside of the cab the cream colour like on the FR, and also cutting the detachable backplate (isn't shown) just above the handrails and taking the roof off so it has a cab like Edrig.
1. Which is the easiest way of cutting the backplate
2. what paints should I use?
any other suggestions welcome! :D :D
PCLR
Post by PCLR » Sat Dec 26, 2009 11:22 am
were your swaping chassic your weaking all the joints
some mamod just never run right in the first place
(If works don't mend it !!!)
Post by DolwyddelanLightRail » Sat Dec 26, 2009 11:24 am
all the joints were pretty weak in the first place, I don't think it'll make any difference! :lol:
I think brit will run now, it's just that I don't have anything thats giving off enough heat to steam her properly at the moment!
PCLR
Post by PCLR » Sat Dec 26, 2009 11:26 am
a leak is a leak it will make a diffrentence mamod are just toys there not design as a proper loco
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Sat Dec 26, 2009 1:10 pm
I cut the back plate on an MSS down with a hacksaw way above the intended line and then filed it down to the correct level. I took the roof off and cut off the top roof side support bits. The loco belongs to a friend and I sent it off after having spent months scratching my head and ordering new pieces for it (Its a long and irritating story) to dream steam who are currently seeing to it. I'll get some pics as soon as possible. Just go in with a saw no where near where you need to cut it down to and finish it off with a file. This avoids embarasing mistakes!
mhlr
Post by mhlr » Sat Dec 26, 2009 1:49 pm
You need some way of supporting the half back too somehow, that will allow you to take the half back off to access the burner etc.
Post by Dr. Bond of the DVLR » Sat Dec 26, 2009 2:05 pm
hmmm, I was just thinking of beding the locating tabs back on them selves. The burner can allways be slid out from the bottom of the loco if it is meths an dthe small bolt be accessed with small pliers.
Post by DolwyddelanLightRail » Sat Dec 26, 2009 2:07 pm
hmm, bu99er, didn't realise that! :?
Unless I do it very simular to how you did the back to Columbine?
What paint is suitable for the cab as well?
mhlr
Post by mhlr » Sat Dec 26, 2009 2:12 pm
made the back to Columbine from tinplate, it has tabs at the bottom to locate into the original slots, and at the top, it clips onto that spring clip.
You can use just normal humbrol or spray paint etc for the cab.
Post by DolwyddelanLightRail » Sat Dec 26, 2009 6:57 pm
Today I have cleaned her up from the failed run she had with tablets, so she was really dirty, so i disassembled the tanks and boiler from the chassis etc and I cleaned her up, and while re-assembling, I thought that she will be better with the cab roof still on, but with the detachable bit half cut above the handrails, and this may in the future be a possibiliy to add a small coal holder
