SM 45 track
- Dr. Bond of the DVLR
- Retired Director
SM 45 track
There is no track section on this forum so I have put this here.
I am rebuilding my railway and want to move away from my Guage 1 scale track.
I am looking for SM 45mm trackrto represent 2 ft 9 and 3/4 inch gauge. I DO NOT WANT G scale track but SM 45 track with a slimer rail profile. I do not have heavier locos so do not need a heavier profile which I think looks ugly.
I can not find any SM 45 track and can only find G 45 track which I do not want. Can anyone help?
- Retired Director
- andysleigh
TommyDodd
Your other options would be to use one of the self-assembled track systems such as brandbright wooden sleepers with either chairs (for bullhead) or pins (for flat-bottom), buy in FB rail only and make your own spiked track (you need a table saw for this, really), or opt for the ultimate in self-sufficiency and go for 100% recycled railway. Rick Collett did this and wrote it up in SMT a few years ago. The ingredients were ballast (swept up chippings after roadworks), sleepers (old railway sleeper sawn up which Rick got for free since he worked for BR at the time) and rail (a double thickness of the steel banding used to hold bricks on pallets, scrounged from building sites who were happy to be rid of the stuff).
- Retired Director
TommyDodd
I haven't done it myself but know people who have. The general verdict is that it's fine provided a suitable amount of care is taken, but labour intensive if there's a lot to do. Building a jig helps. Some systems have their weaknesses e.g. the brandbright chaired track- the "push in" chairs come out after a few years weathering, so some experienced users recommend glue. The biggest difference is that the stuff is rigid when assembled and won't bend to a curve, so if you want a curve of X' radius you have to build it like that.Mr. Bond of the DVLR wrote:Hmm, how easy is the self assembly stuff?
I think I'd echo all of that, but I'm wedded to it as I started off with it (coz at the time Peco wasn't completely stable in sunlight) and it would cost too much to change to Peco now!TommyDodd wrote:I haven't done it myself but know people who have. The general verdict is that it's fine provided a suitable amount of care is taken, but labour intensive if there's a lot to do. Building a jig helps. Some systems have their weaknesses e.g. the Brandbright chaired track- the "push in" chairs come out after a few years weathering, so some experienced users recommend glue. The biggest difference is that the stuff is rigid when assembled and won't bend to a curve, so if you want a curve of X' radius you have to build it like that.
Having said that, it smells GORGEOUS after the annual creosote treatment!
minimans
What size is the rail that your after? normal 'G' Scale (How I hate that phrase) is code 332 but ther is an awful lot of code 225 about from various manufacturers including accucraft and aristocraft now i believe. I have about 400ft of code 225 aluminium rail here in the states going spare but it doesn't do you much good "over there" as it were........................
- Retired Director
Does anyone have a picture of the Peco G 45 track? If the profile IS smaller than G scale track I may go for it.
Getting the G45 track, removing the sleepers and rebuilding them really does defeat the object of having a smaller profile than the G45 track!
How easy is the self assembly stuff to bend (I'll be doing alot of twists and bends in the track) and get smooth corners and how does it work out price wise?
SillyBilly
PECO G45 uses Code 250 rail, as does this Accucraft track:
www.track-shack.com/index.php?cat=AMS_Code_250_NG_Track
So that should give you a genereal idea of it.
- Retired Director
- andysleigh
pauly
- andysleigh
its part of the religion,pauly wrote:whats with you Andy?andysleigh wrote:a good reason to convert to 32mm gauge thenMr. Bond of the DVLR wrote:Still looks too chunkey rails. I really like the lightweight look of the SM32 stuff.:D
all you ever try to do is convert people and argue about Edrigs :lol:
like JW's
Endless, Nameless
The Accy track isn't the best example. Massively chunky sleepers. The Peco G-45 looks much better- far lighter than LGB. The rails are a larger profile than SM32 but they look fine- I'd say the rail profile compares well scale wise to, for example, the W&LLR (or the Welsh Highland, except that's 2ftish, and yes I know the W&LLR is 2'6" which doesn't scale to 45mm either). If not, make yer own- or use gauge 1 which costs the earth and hide the sleepers in deep ballast!
Personally I'd quite happily use Peco G-45. It's very different to LGB.
- Retired Director
PCLR
