Hartland Mack loco conversions
gregh
Post by gregh » Fri Nov 06, 2026 9:50 pm
I hope many of you know of the Hartland Mack loco series. These cheap little locos had a great motor block for scratchbuilding or for just bashing the body into something else. Unfortunately I believe they are no longer available.
I had previously used these motor blocks to produce 3 different locos, shown here with an unchanged Mack.
composite mack locos sml.jpg (361.38 KiB) Viewed 1293 times
Years ago I inherited one from a mate who had turned it into a Ute by adding a tray to the back.
He had added a battery and a simple forward/off/reverse switch. I did not use it much.
Recently another mate died and before-hand he returned some remote control stuff I had built for him years ago. So as a ‘memorial’ to both these mates,’memories I put Geof’s RC and sound into Bryan’s Ute. It will mainly run on my indoor line, so I purposely made the sound quite soft.
The RC is my usual model aircraft 2.4GHz stuff with a picaxe speed controller and sound. The electronics went in the ute’s tray and I covered it with various loads, mainly made from balsa. The small LiPo battery is underneath behind the motor block as is the speaker.
charge details.jpg (273.56 KiB) Viewed 1293 times
finished (2).jpg (401.6 KiB) Viewed 1293 times
and a low resolution video on my inside line.
Greg from downunder.
Re: Hartland Mack loco conversions
Post by ge_rik » Sat Nov 07, 2026 8:32 am
A great looking little loco, Greg, and a fine tribute to Bryan and Geof. Sounds good, too!
Post by Peter Butler » Sat Nov 07, 2026 10:55 am
That's a great little loco Greg, looks good and handles the curves and inclines so well.
Users browsing this forum: No registered users and 64 guests
