Separating wheels from axles
- Allu
I am planning to build a small industrial diesel loco and I was planning to use Brandbright wagon wheels for it. Does anybody know how hard/easy is to dismantle the wheels from the axles in order to install the cogwheel, are they pressfit? Or are there some other alternatives? I think the wheel diameter should be around 20 mm.
Allu
Allu
- StuartJ
Re: Separating wheels from axles
Separate wheels and axles are available from https://peterbinnie.com/ and are used in many loco kits
- Allu
Thanks, looks like they have a good selection indeed. I was hoping to get all-steel wheels though as they give some additional weight and robustness, but probably the easiar solution are the binnie onesStuartJ wrote: Tue May 19, 2026 11:02 am Separate wheels and axles are available from https://peterbinnie.com/ and are used in many loco kits
Allu
Allu
Another source is IP Engineering. They have 20mm wheelsets in steel
https://www.ipenginnering.com/wheel-sets
- Allu
Any experiences with removing the steelwheels from their axles and possible best practices?
Allu
Allu
Not sure if it applies to Brandbright, but when I couldn't remove the wheels from the axle in a HGLW kit, I was advised to apply a bit of heat to loosen the Loctite which had been used to hold them in place.Allu wrote: Tue May 19, 2026 2:59 pm Any experiences with removing the steelwheels from their axles and possible best practices?
I then placed the wheels over the jaws of a small vice and gently tapped the axle with a hammer (using a piece of wood between the hammer and the axle to protect it)
That's what I would try myself.ge_rik wrote: Wed May 20, 2026 8:59 am
- GAP
Been there done that worked OK just be gentle
