Spring winder upper thingy....
Bad Droid
Post by Bad Droid » Mon Sep 16, 2024 12:00 am
I built a "spring winder upper" out of some parts in the pump house/tool shed. Think I'll add an 8-32 and a 10-32. The springs are for my sprung trucks.
Pretty stupid simple, took about 20 minutes to build.
It has a crank handle, a spring to make sure you don't hit the uppy downey part, and I drilled a hole in the thread to hold the wire. The wire is from my mig welder. I have simple wire for sheet metal, and stainless. The basic wire is best but either will do...
Bad Droid
Re: Spring winder upper thingy....
Post by Bad Droid » Mon Sep 16, 2024 12:20 am
Sorry, that 1st pic was horrible (now deleted) in showing the apparatus.
Maybe this is a bit better. Still waiting for my new phone.....
Post by LNR » Mon Sep 16, 2024 12:28 am
I find if you just hold the end of the spring against the grinding wheel till it turns red you can then flatten enough of the last turn to square up the spring.
Post by ge_rik » Mon Sep 16, 2024 7:23 am
Very clever, especially the use of threaded rod - though does that make it tricky to get the spring off?
Bad Droid
Post by Bad Droid » Mon Sep 16, 2024 1:57 pm
ge_rik wrote: Mon Sep 16, 2024 7:23 am Very clever, especially the use of threaded rod - though does that make it tricky to get the spring off?
No, you just clip the part that goes through the rod and then un-thread the whole works. :thumbup:
Bad Droid
Post by Bad Droid » Mon Sep 16, 2024 1:58 pm
LNR wrote: Mon Sep 16, 2024 12:28 am I find if you just hold the end of the spring against the grinding wheel till it turns red you can then flatten enough of the last turn to square up the spring.
Good to know, thanks!
Bad Droid
Post by Bad Droid » Wed Sep 18, 2024 8:52 pm
I went from a 1/4 × 20 to a 10-24 all-thread for the springy maker machine. Much better! Still figuring out how long to cut the springs and how much to stretch them out, but they're working out great, between the printer and some scratchbuilt stuff...fully sprung, 100% DIY trucks!
I'm working on some modified 4' passenger trucks as well for a not too distant build. But in those, even though the leaf springs turn out amazing, the printed coils springs are a little goofy. I plan on cutting those out, spinning up my own coils on the 1/4 x 20 thread and going from there. Although the passenger trucks are not fully sprung, they look awesome.
More to come....
Post by drewzero1 » Thu Sep 19, 2024 3:20 am
This is great, now I can stop "borrowing" all those retractable pens from the office!
Post by LNR » Thu Sep 19, 2024 9:01 am
Ha! Ha! my source for many springs also.
Bad Droid
Post by Bad Droid » Fri Sep 20, 2024 10:12 pm
drewzero1 wrote: Thu Sep 19, 2024 3:20 am This is great, now I can stop "borrowing" all those retractable pens from the office!
That's what I'm talkin' about!
Post by Old Man Aaron » Wed Sep 25, 2024 3:42 pm
Quick, cheap and a tidy result. Can't go wrong. :thumbup:
