Playing in the garden yesterday
Links to and discussion of garden railway video footage or videos of real railways which might inspire members with their modelling
Tony Bird
Post by Tony Bird » Sat Aug 10, 2024 4:18 pm
Hi,
Take care Tony.
Re: Playing in the garden yesterday
Post by ge_rik » Sun Aug 11, 2024 7:43 am
Single oscillating cylinder? Is it geared? It runs at a sensible speed.
Tony Bird
Post by Tony Bird » Sun Aug 11, 2024 8:02 am
Hi Rik,
Yes, a single acting oscillating engine. Yes, again geared 4:1. No regulator, speed altered by gas pressure and load.
Better explanation at:
Take care Tony.
Post by ge_rik » Sun Aug 11, 2024 10:23 am
Tony Bird wrote: Sun Aug 11, 2024 8:02 am Hi Rik,
Take care Tony.
Thanks. That makes a lot of sense. I like the notion of blowtorch firing. Presumably a precursor to gas firing.
Tony Bird
Post by Tony Bird » Sun Aug 11, 2024 5:31 pm
Hi Rik,
The blowtorch works okay but has really to be lit while it is outside the boiler.
I don't think so. Merlin/Beck were using poker burners in the late 1970's. I think the reason was simplicity. I think the design criteria was along the lines of; the model doesn't have anything it didn't need to work. Hence no regulator or safety valve. Motive power one single acting oscillating cylinder with no reverse. Using gears meant that no side rods were needed. The burner being from a pencil blowlamp.
I haven't made a Cracker since 2010 and I always said i would make a 7/8" scale version. Well I have recently started making one. To try and keep it as simple as possible I am using Meccano wheels and gears, The single cylinder will be double acting from a Mamod locomotive.
Take care Tony.
DSC05202 crop LR.jpg (230.14 KiB) Viewed 50493 times
DSC05199 crop LR.jpg (206.08 KiB) Viewed 50493 times
